Platform: J-body
what is needed to put a turbo on a 92 cavalier
Old May 7, 2009 | 9:56 AM
tray20's Avatar
Default what is needed to put a turbo on a 92 cavalier
i have a 92 cavalier and i was just wondering if you can put a turbo on a completely stock 92 cavalie. if not what are the basics needed
Old May 7, 2009 | 1:05 PM
OnDaGround's Avatar
Is it a 2.4 or a 3.1? BTW to respond to your question.... do you want me to scare you by telling you the truth or do you want me to lie?
Old May 7, 2009 | 5:52 PM
WAAAY too much time, effort, and most importantly, money
Old May 7, 2009 | 9:51 PM
tray20's Avatar
i believe that it is a 2.2 and tell me of the price and time and other mods needed
Old May 8, 2009 | 6:24 AM
HotSauce6226's Avatar
Impala Super Moderator
One hell of a wallet, supporting mods and a killer tranny
Originally Posted by 1Gary
Check out this link:
http://www.turbo-kits.com/cavalier_turbo_kits.html
The pricing is scarely
That price is cheap compared to the impala kits, 4k and up
Old May 8, 2009 | 9:33 AM
OnDaGround's Avatar
Very cheap. Hell to turbo a saturn with new parts... you're looking about 5-8K depending on where you get it. A cavalier is similar to a saturn in that they are not worth that amount of time, money and effort. If you want my honest suggestion and you are hell bent on making that car go fast... n2o. Best solution for cheap power. I would maybe max do a 50 shot on that car. Use a fogger system so you don't blow it up and it can be distributed evenly across all 4 cylinders.
Nitrous and Turbos are not good ideas on cars that have not been well taken care of, that have low compression, or a car that you think is iffy with reliability. Unless you have a daily driver I wouldn't even bother thinking about it. A 50 shot is safe on the stock internals if the car has been cared for properly. Maybe a 75 shot, but I wouldn't even chance it. A 50 is plenty. The car doesn't way a whole lot. I would do some extensive reading before getting involved in it. Nitrous and turbos have a lot more to them other then boost and extra o2.
Old May 8, 2009 | 9:43 AM
OnDaGround's Avatar
For a turbo you are going to need atleast the following:
turbo
manifold
oil cooler
oil supply and return lines
coolant supply and return lines
exhaust manifold gaskets
turbo->d-pipe gasket
Drill
Stand alone fuel controller
Fuel pump
Injectors
Intercooler
Intercooler piping
Random washers for turbo lines
Exhaust studs
Possibly head gasket and head bolts/studs (depending on boost)
Diverter/BOV
might as well invest in poly eurothane mounts....
that is a minimum. I forgot to add stuff but you catch my drift. You will be drilling some stuff out. For example a hole in the oil pan for the return oil line.
Old May 19, 2009 | 8:33 PM
a. palmer jr.'s Avatar
If you want to go fast with little money why not just buy a Camaro or Mustang or something that will go faster without straining the engine. It would be cheaper in the long run than all the maintenance you'd need with a turbo'ed Cavalier.
a5ht0n
Sep 11, 2014 11:17 PM
nomad1
Dec 29, 2012 11:37 AM
04yellowECO
Aug 9, 2010 3:04 AM
UKChevyJules
Sep 23, 2008 5:42 PM
FairTax
Feb 18, 2007 5:01 AM
