Go Back   Chevrolet Forum - Chevy Enthusiasts Forums > General Discussion Forums > General Tech
Old 05-09-2009, 12:30 PM
Ride of the Month
April 2009
2000 Chevrolet Blazer
My Garage
Default FAQ: Fix for Rail Dust in Paint (Rust Spots)
Several people have asked about rust spots in the paint of a relatively new vehicles. Heres the most likely cause of the problem and the solution to the said problem.
  • Symptoms: Visible grains of iron or rusting spots in the paint surface.
  • Models Affected: 1994-2007 GM Passenger Cars and Trucks.
Commonly looks like (click to enlarge):
Where does it come from?
Rail dust comes from tiny iron particles produced from the friction between train wheels and the tracks and gets deposited on the vehicle surfaces. Iron dust can get deposited on the surface if the vehicle is stored near any operation producing iron dust such as a steel ore yard. Either material can lay on top of, or over time, become embedded in the paint surface.
Illustration of surface rail dust and embedded rail dust:
Because the severity of the condition varies, proper diagnosis of the damage is critical to the success of repairs. Diagnosis should be performed on horizontal surfaces (hood, roof, deck lid, pick up box, etc.) after the vehicle has been properly cleaned. There are two types of repair materials recommended to repair rail dust or iron dust:
Gel Type Oxalic acid (Fallout Remover): - Has the characteristics of the liquid type oxalic acid but stays where you put it because of its gel consistency.
Clay Bar: - Requires surface lubricant during use.
Caution:
Rail dust remover (Oxalic Acid) is an acidic substance containing chemicals that will break down the iron particles embedded in the finish. When working with rail dust remover, use the necessary safety equipment, including gloves and goggles. Follow the chemical manufacturer's directions closely because it may require special handling and disposal.
If, upon inspection, some particles are still present, the various chemical manufacturer's processes can be repeated.
After the removal process, small pits may remain in the clearcoat and can be corrected, in most cases, with a finesse/polish/buffing operation.
Procedure
Move the vehicle to a cool shaded area and make sure that the vehicle surfaces are cool during the removal process. DO NOT PERFORM THE REMOVAL PROCESS IN DIRECT SUNLIGHT OR ON A VEHICLE WITH HOT OR WARM BODY PANELS. Wash the vehicle with soap and water. Dry it immediately and clean the affected areas with a wax and grease remover.
Perform the removal process according to the chemical manufacturer's directions.
Once the damage has been repaired, the final step involves a polishing process.
Where do I find Rail dust remover or Clay bar?
Napa and Sherwin Williams carries Rail dust remover.
Clay bar can be found at any place that carries car care products.
Old 07-06-2009, 06:19 AM
daniel86 daniel86 is offline
Great post.
__________________
Signature removed by Admin. If you would like to advertise on the site, please contact me for more info.
Old 07-06-2009, 07:51 AM
Ride of the Month
April 2009
My Garage
Thank you.
Tags
acid , car , cars , chemicals , chevrolet , damage , dust , fix , oxalic , paint , rail , raildust , removal , remover , rust , spots
HTML code is On
