How can I bypass factory amp
Old May 14, 2009 | 9:25 PM
95burban's Avatar
Question How can I bypass factory amp
how do i bypass factory amp 95 suburban I put a new cd player in and now the highs turn off when i turn it up then i have to turn the deck off for minit turn it back on then it works butt if i turn it up the high turn off just the subs are working any one know how to bypass the factory amp????????
Old May 15, 2009 | 6:06 AM
HotSauce6226's Avatar
Impala Super Moderator
There is alot more behind it than this. The amp is protecting your stereo for a reason. Plus, what ohm are your factory speakers?
What ohm is your HU?
Old May 15, 2009 | 3:43 PM
95burban's Avatar
Its a kenwood it works fine in my car (Loud) took it out for the Burban,,,
dont know the ohms they are stock speakers im just going to wire it up strate to the deck bypass all the bull ****,,
Old May 15, 2009 | 4:20 PM
And you will mess up your HU.
You need to know the ohms first. Unless you add an aftermarket amp
Old Sep 13, 2009 | 2:49 PM
durtiJ's Avatar
Sorry HotSauce6226 but you are wrong on this matter. The problem is the aftermarket head unit pushes to many volts through the factory amplifier causing it to clip. The solution should be to simply unplug the factory amplifier. BTW this isn't going to mess up your head unit.
Old Sep 14, 2009 | 3:32 PM
HotSauce is right actually.....lets say the front doors are rated at 2ohms, and the front tweeters are at 2ohms as well.....put them together and you get 1ohm, thats enough to overdrive\overheat the headunit and cause damage.
Most headunits are made to work on speakers rated at 4ohms
Old Jun 19, 2017 | 7:44 PM
Monty Brock's Avatar
Default Speaker
Hi I'm having a problem with right turns and bumps cutting my speakers out, I was wondering if you could give me advice on what to do.
noxlanding
Oct 26, 2020 5:03 PM
Raptormann11
Feb 16, 2013 6:16 PM
nikkijdcb
May 4, 2010 8:21 AM
Tony F
Oct 25, 2008 5:37 PM
bradstump
Sep 21, 2006 10:42 PM
