Go Back   Chevrolet Forum - Chevy Enthusiasts Forums > Chevy Trucks, SUV's, & Crossovers > K5 Blazer
Old 05-14-2009, 10:58 PM
pcharles pcharles is offline
Default K5 Blazer Stalling
I just bought a 85 K5 and had new belts put on, and fluids changed. Drove it home and on the way it stalled out on me. It would start back up and I would go to put my foot on the gas and it would die. It keep doing that so I called the place that did my service. They towed it back to the shop. changed the fuel pump, rebuilt the Carbuerator, new starter, Reset the timing. I picked it up and the same thing happened. can you help please? Register today for free or log-in if already registered to remove this ad!
Old 05-14-2009, 11:06 PM
suzuki-guy's Avatar
suzuki-guy suzuki-guy is offline
General Discussion Moderator
1995 Chevrolet C/K 1500
Welcome to the forum! Stop by the New member welcome area if you would like!
Fuel delivery problem. Check your pump, and filter!
__________________
1995 Chevy K1500 355 5 speed manual 4:56 gears 35"tires
Old 05-14-2009, 11:10 PM
Thanks for the welcome!
Both the pump and the filter have been replaced since the first stall. It didn't seem to fix the problem.
Old 05-14-2009, 11:38 PM
suzuki-guy's Avatar
Hmm did you verify the timing yourself?
__________________
Old 05-15-2009, 12:04 AM
No, the shop did and they checked all the spark plugs. It's sparking fine.
Old 05-15-2009, 12:07 AM
suzuki-guy's Avatar
Hmm.. Im stumped here... Did you check fuel pressure? Kind of sounds like idle/air mixture screws could be off to.. The way i do those is screw them all the way in then two and a half turns out. Does it pop when it quits? Like out of the carb.?
__________________
Old 05-15-2009, 08:09 AM
Yes. It does pop when it quits. I have talked to different people and some say there could be a leak from the manifold. The last thing the shop told me is that they sprayed on the right hand side of the motor and the idle fluctuated, but in a good way. Could it be that?
Old 05-15-2009, 02:09 PM
suzuki-guy's Avatar
Yes it could be a vaccum leak! Check your intake, also check all your vaccuum lines!
__________________
Old 05-16-2009, 10:47 PM
Ok another issue. Back power window motor goes down, but hit the switch to go up and nothing. So window is now down. Can anyone help.
Old 05-18-2009, 07:38 PM
Ok, After a new fuel pump, starter, Rebuilt Carb, Fuel filter, timing adjusted, and now new manifold gaskets, it ran great last night, today to work back home again it sat for a hour went to drive around the block and it tried to pop and shut off again. I put in neutral revved it up again and got it home. Anyone please help.
fficeffice" />>>
Tags
1995 , chevy , issue , k1500 , k5 , power , problem , stalling , window
HTML code is On
