S-10 & Blazer 1982-2005
Stalling issue at cruising speed with 4.3L
Old May 21, 2009 | 11:55 AM
Schveb's Avatar
Default Stalling issue at cruising speed with 4.3L
<!-- / icon and title --> <!-- message --> <!-- google_ad_section_start -->At this point i'm stuck.
2000 4.3L
I have tried everything to my ability to keep my truck from stalling at cruising speeds and even sometimes during acceleration (the late not that frequent)
I have change distributor, plugs, and wires with no success. I have cleaned my MAF sensor with no obvious change. I have tried to run with the MAF disconnected to see if it clears up but again no big change. I haven't been able to electrically test it because i don't know how. I can't find anything on how to do it. The only other idea that comes to mind is my cat. It rattles at take off and when the engine decreases in rpms drastically but i am getting no error codes that have to do with the cat or the 02 sensors. teh only codes i have got so far are random misfire codes. The truck only has 102000 miles on it and i don'ot know how oftenm the MAF goes bad but i did use the fram pre-oiled filter last change and i heard that it may cause the MAF to get dirty.
But again, the only problems i'm getting are engine stalling during the crusing speed and ocassionaly when i'm accelerating from a stop to highway speed. It does seem to do it more often in the morning than in the afternoon but i cant see why moisture would be the cause especially after i change the distributor and wires. Could it be the coil?
Any suggestions would be greatly appreciated!
Old May 21, 2009 | 12:52 PM
A good starting point would be to run the codes on it. That will narrow the broad range of possibilities down quite a bit.
Old May 21, 2009 | 12:55 PM
Schveb's Avatar
Well i had the code pulled off it and like i said the only codes i've gotten were random cylinder misfires a P0300 Engine Misfire Detected code.
Old Sep 18, 2017 | 9:05 PM
charles lindenschmidt's Avatar
Coil...
jrhope
Oct 14, 2023 4:02 PM
levi3
Mar 5, 2011 7:07 PM
levi3
Mar 4, 2011 9:45 PM
Overnite
Astro
13
Nov 9, 2010 6:48 AM
