Silverado DIY and Useful Threads This section is for Do-It-Yourself articles and other informative FAQ threads. If you would like to submit an article, contact a member of staff!
How to: 2004 HID Install Step by Step (Pics included)
Old May 27, 2009 | 7:50 PM
ActiveMonkey's Avatar
Default How to: 2004 HID Install Step by Step (Pics included)
9006 bulb 6000k HID Kit
1. Starting with the driver side headlight.
2. Lift and remove metal retaining pin.
3. Lift and disconnect small plastic clips on headlight wires.
4. Remove low beam bulb.
5. Insert the 9006 HID Bulb.
6. Attach wiring harness
7. Plug the wiring harness into the ballast and mount it where ever you can.
<<<NOTE>>>
I had to reverse the polarity when installing my kit
(Plugs that lead to Bulb.)
(Plug that leads to OE Connector)
<<<Plug everything in and remount the headlight>>>
Repeat with remaining headlight and you’re done.
badOHtenTAHOE
15
Sep 8, 2023 8:08 PM
ActiveMonkey
21
Jun 26, 2015 11:24 AM
pcursed
Jan 7, 2012 10:41 PM
Cassera
Sep 20, 2010 8:20 PM
RoflCopter726
Mar 14, 2008 10:19 AM
