TrailBlazer 2002-2009
05 driver side control panel not working...
Old Jun 2, 2009 | 10:47 AM
Jackals7's Avatar
Default 05 driver side control panel not working...
The driver side control panel doesn't work. No locks, no windows, no side mirror adjustment, no light on the window lock. I popped off the control unit and unplugged and replugged everything back in. Sometimes it works and sometimes it doesn't. Everything works fine on all the other doors.
Any ideas?
Thanks!!
Old Jun 2, 2009 | 11:04 AM
Mike Sigmond's Avatar
ROTM Coordinator
Has it ever been wet from rain etc..?
Old Jun 2, 2009 | 11:22 AM
Jackals7's Avatar
I'm sure that at some point it has. Not sure how recent however its been. I would guess its the unit on the door just because all the others work. Even the doors will all lock except the drivers side with the keyless fob.
Old Jun 2, 2009 | 11:25 AM
ROTM Coordinator
Does it look like you can get the board out of the door and clean it with electrical cleaner? I have done that on other boards and they worked fine after cleaning the rust & calcium off from water damage. Sometimes they do blow resistors etc and need to be replaced.
Old Jun 2, 2009 | 11:28 AM
Jackals7's Avatar
I have nothing to lose right? I'll give it a try
Old Jun 2, 2009 | 11:30 AM
ROTM Coordinator
If its unplugged , your fine to clean it. Let us know what happens
Old Jun 2, 2009 | 12:12 PM
Jackals7's Avatar
When you say "board" do you mean the guts inside the black box that the window & lock controls are on? or just clean the 4 or 5 plug connections in the bottom of the box?
Old Jun 2, 2009 | 12:14 PM
ROTM Coordinator
Yea, I meant the circuit board the that the controls are on, the connections too.
Old Jun 2, 2009 | 12:24 PM
Jackals7's Avatar
ok thanks, I'll try and do it tonight
Old Jun 2, 2009 | 12:31 PM
ROTM Coordinator
Which sub model do you have? LT LS etc. & motor size. I can get you a schematic for it.
