Venture 1997-2005
Platform: U-Body
Rocker Switch Back Lighting - 2000 Venture
Old Jun 9, 2009 | 6:36 AM
bertherr's Avatar
Default Rocker Switch Back Lighting - 2000 Venture
Do each of the rocker switches in the overhead console and below the HVAC controls have their own bulbs for back lighting? I have a couple that do not light up and I do not remember if they ever did. If yes, do you know how to get to the bulbs for replacement? Thanks, Bert
Old Jun 9, 2009 | 11:14 AM
Mike Sigmond's Avatar
ROTM Coordinator
Here is your schmatic for the inside lamps. It looks like they do have lights, but I am not sure. It shows 4 bulbs in the Heat /AC controls. I would pull it out and see to know for sure.
Welcome to the forum!
Attached Thumbnails Rocker Switch Back Lighting - 2000 Venture-chev_venture_ac_cntrl_overheadl.gif
File Type: pdf
Old Jun 10, 2009 | 6:29 AM
bertherr's Avatar
It looks like the diagram you sent is for the rear HVAC controls . Thanks, but I am talking about the rocker switches, i.e. the rear wiper switch below the dash's center stack HVAC controls, and the forward overhead rocker switches for the power sliding door, etc. Thanks, Bert
Old Jun 12, 2009 | 9:23 PM
eddieov678's Avatar
Default How Do you post a question in this forum?
For the life of me I can't figure out how to post a question
Old Jun 13, 2009 | 12:20 AM
ROTM Coordinator
Well you seemed to post one here, just hit the new thread button in the section you have a question in.
Old Jun 13, 2009 | 12:22 AM
ROTM Coordinator
Ahh I see, I guess my database only covers it in general , I didnt see any other HVAC diagrams in my database for your vehilce, maybe they are the same wiring just different panels. Cant you pull it out and look at it to see?
Old Jun 13, 2009 | 10:59 AM
HotSauce6226's Avatar
Impala Super Moderator
Looks like you have a bulb out. I can fix it.
Old Jun 23, 2009 | 9:33 AM
bertherr's Avatar
I have been away for a week so I am just getting back online to take a look here. What do I remove in what order to get to the back of these rocker switches? I guess if I have to, I can go to the junk yard and practice there before trying to take mine apart. Thanks, Bert
Old Jul 31, 2009 | 11:16 AM
bertherr's Avatar
I went to the junk yard to find out how to do this on their vehicles. Actually, someone else had already done some of the work for me. The overhead console drops down as an assembly after removing a screw that is under the flip down door to the rear. From here you have access to the back of the switch assembly. You have to pry this thing apart to get to the bulbs. It does not seem that taking this apart was in mind when it was designed.
There were only three locations for bulbs for the four rocker switches (plus one blank in my case). So, I do not know if these three bulbs are meant to light each switch or not. Does anyone else with these overhead switches have each one light up when the headlights are on?
Thanks,
Bert
gavinx
Feb 12, 2014 7:52 PM
somerandomguy
Sonic (Aveo)
May 2, 2012 1:44 PM
bojo
Nov 19, 2009 12:15 PM
Arkmasr1
Aug 30, 2009 8:15 PM
baby141
Feb 29, 2008 11:24 AM
