'08 Tahoe LT Grinding Noise
Old Jun 29, 2009 | 4:19 PM
ChevyHDNutt's Avatar
Default '08 Tahoe LT Grinding Noise
I have a 2008 Tahoe 4WD that has just recently started making a real low grinding noise on start up / Cutting A/C on. Not sure what this noise is, My suspicion is that it may be coming from something to do with the A/C. My dealer heard that noise when I took it in to them but they do not know what would be causing this. Anyone else out there experiencing these grinding noises on start up, etc??? ANY help and/or advice would be GREATLY appreciated.
Old Jun 29, 2009 | 5:00 PM
Willys 53's Avatar
Is this the noise? http://smg.photobucket.com/albums/v6...27-08_1118.flv
If so, have the Dealer reference GM Document ID #2022356; the fix for this is bulletin 07-01-38-010 and it is the reprogramming of the ECM. Thanks to the great info from this Forum, the ECM reprogram fixed this problem on my '07 Suburban - and I haven't heard it since! Good luck.
Old Jun 29, 2009 | 7:19 PM
d1nonly34's Avatar
I have that same problem, the sound isnt constant, it happens when it wants to, its annoying and loud! When I get home Ill listen to the audio file to see if its the same noise
Old Jun 30, 2009 | 7:43 PM
Search the forum for this. One suspect cause was the A/C compressor.
Old Jul 1, 2009 | 3:07 PM
****** 53 that is the noise... I will call my dealer and ask them about the bulletin and update and try that. If that doesnt fix it then I will start investigating the compressor.. Thanks all for the help!!
Old Jul 12, 2010 | 3:50 PM
momto2babybruces's Avatar
How do i go to the photobucket account to view your video of the noise? Mine is doing the same thing it sounds like, but of course wont do it at the mechanics. He is saying he needs to hear it to know what it is. Im so frustrated
Old Jul 13, 2010 | 10:33 AM
AZSCTACO's Avatar
I took that video....there is a TSB for this. It is a software update. Something to do with delaying the A/C. Don't know the specifics but it's out there. Tell the mechanic to do his job and research and get it fixed.
Old Jul 13, 2010 | 10:37 AM
AZSCTACO's Avatar
For future referance......
Old Sep 18, 2021 | 11:17 AM
TWillp's Avatar
Default Motor mounts
Have them check your Motor Mounts. The one on the Driver side goes bad.
Old Sep 18, 2021 | 11:18 AM
TWillp's Avatar
Default Check Motor Mounts
Dan75208
Dec 18, 2021 12:42 AM
eclarsen
Nov 2, 2014 12:31 PM
Schill
Feb 23, 2013 2:14 PM
chuck5001
Jan 1, 2013 4:22 PM
fstrecon8653
Feb 7, 2010 2:57 PM
