Go Back   Chevrolet Forum - Chevy Enthusiasts Forums > Brand Review > Computer, Ignition, & Fuel Systems
Old 06-30-2009, 11:05 PM
4.3 power 4.3 power is offline
Default 4.3 fuel injected swap
Hi, I am swapping a 1993 4.3L out of a safari van into a 1990 4runner. I want to dual the exhaust but I am not sure what to do with the o2 censor. Factor the engine only has one censor where the exhaust comes together into one. After separating the exhaust how do I hook up another censor? Do I just choose a side to put the censor? how much would get screwed up if I leave the censor un plugged? Thanks. Register today for free or log-in if already registered to remove this ad!
Old 06-30-2009, 11:17 PM
suzuki-guy's Avatar
suzuki-guy suzuki-guy is offline
General Discussion Moderator
1995 Chevrolet C/K 1500
I did the same thing i just moved my o2 sensor on my driverside exhaust manifold! The plug in runs up there anyways. Trace the wire from your existing o2 sensor and plug the new one in at the manifold.
__________________
1995 Chevy K1500 355 5 speed manual 4:56 gears 35"tires
Old 06-30-2009, 11:25 PM
1Gary's Avatar
1Gary 1Gary is offline
Thumbs up
I have seen in Astro/Safari's run duals before and what they do is to run a H-pipe before the 02 sensor.Simple fix and a improvement to boot.
Old 06-30-2009, 11:31 PM
suzuki-guy's Avatar
True true. I would run an H or X pipe anyways with true duals to balance the power and sound. But there should already be a bung for your O2 sensor on the exhaust manifold. Either way will work and it's best to leave your o2 sensor plugged in!
__________________
Tags
1994 , 43 , 43fuel , caprice , chevy , duals , forum , forums , fuel , injected , swap , toyota4runner , true , v6 , van
HTML code is On
