Go Back   Chevrolet Forum - Chevy Enthusiasts Forums > Chevy Trucks, SUV's, & Crossovers > Tahoe & Suburban
Old 07-02-2009, 07:36 AM
ammar456 ammar456 is offline
Default Replacing HeadUnit
I have a 08 Tahoe LT that comes with a 6 CD changed. I'm looking to replace the factory unit with a double-din screen, but my audio guy tells me i'm going to lose functionality of the stereo controls on the steering wheel, plus my rear parking sensors wont work (ie, they wont beep).
Anybody know a specific way around this, or know of any headunits that are made for this? thanks
Old 07-02-2009, 01:27 PM
SabrToothSqrl SabrToothSqrl is offline
Default audio
I'm not sure if the backup beeps are played through the sterio; but I know the turn signal ones are...
why GM does this, I have no idea.. saves them $0.03 for a standard under the dash speaker...
causes after market people headache after headache...
__________________
...Need $, will settle for ˘...
2009 Tahoe LTZ (Mikaela)
2004 Wrangler Rubicon, Lifted, Locked & Loaded (Savana)
1995 Tahoe 2 Door (Betsy) (Sold 2009)
Old 07-02-2009, 03:20 PM
shawnvw shawnvw is offline
This module is the shizzit....it is exactl what you need...will make the install a breeze
http://www.pac-audio.com/productDeta...&CategoryID=26
Part Number:
OS-4
Peripheral Part No: GMAHL1
Category: Radio Replacement
Product Overview
OnStar® Radio Replacement Interface for Select 29-bit LAN General Motors Vehicles with or without Bose Sound System
Product Description
  • Retains OnStar® system functionality and the Bose factory-installed amplifier (if present) when the factory radio is replaced in a 29-bit GMLAN vehicle. Generates all safety warning chimes and audible turn signal indicators.
Product Features
  • Retains OnStar® when the factory radio is replaced
  • Retains Bose amplified audio system
  • Provides all navigation radio trigger wires
  • Chime module included
  • Retains all safety warning chimes
  • Antenna adaptor included
  • Retains Bluetooth® in 2009 models (if equipped)
you will also have to buy a separate steering wheel control module, but they vary depending on which headunit you are putting in. buy it from pac also and they are plug and play with the OS4
__________________
Old 10-29-2009, 12:27 PM
crippledfish crippledfish is offline
I am also replacing my oem HU dvd/6disc in my LT3 07 Tahoe with with Pioneer AVIC-Z110bt. I am wanting to retain onstar and back up sensors, but is there any way to disable the door and seatbelt chime, really i could care less about the onstar?
I am also wanting to add a OEM backup camera, does anyone know what is needed to install?
Lastly, the AVIC has voice command, do you think it is possible to splice into the onstar mic overhead instead of installing another mic?
Old 10-29-2009, 01:06 PM
AcousticHoney's Avatar
AcousticHoney AcousticHoney is offline
1997 Chevrolet Silverado 1500
Send a message via MSN to AcousticHoney
http://www.crutchfield.com/App/Tab/Learn.aspx
They are quite helpful, videos, guides & all.
I helped my friend install her head unit, sub & amp yesterday
& used crutchfield as my directions. It was quite simple, & now
I know what to do when I finish collectiong my sound system,
all I need is my head unit & subs box.
__________________
"I walk into the club, passing out hundred dollar bills, and it thrills, and it kills, like the horns on my Silverado grille."
Lyoto Machida ! [15-0-0]
Old 10-29-2009, 01:25 PM
Default why
why does GM make it so complicated? Replacing the head unit on my 95 was easy, in my 04 wrangler, easy... why does GM make it so hard? don't they know that their headunits aren't the world's best?!
__________________
Old 10-29-2009, 03:15 PM
thanks for the reply, but i dont think crutchfield would be much help. I know I need OS-4 PN: GMAHL1 and steering wheel control module, but just not sure how to disable the door chime and if I can use the overhead onstar mic. Anyone have any idea?
Old 10-29-2009, 10:30 PM
Rich E Rich E is offline
Quote:
You'd be surprised about Crutchfield. I've been using them for years and they are very helpfull. When I started planning my install, I called them, told them what I wanted to do and they gave me a list of everything I would need. I wound up getting some things from them but most parts off ebay.
All you need is the PAC-OS4(onstar) and the PAC-SWI(steering wheel controls). The OS-4 allows you to retain ALL Onstar functions including the mic. I wanted to use the Onstar mic for my radio's bluetooth function and was told it could not be done, so I added a seperate mic. You will also retain the backup sensors. Not sure about the door chimes. Maybe you can ask your installer.
Why add an OEM camera? Just get an aftermarket one. If your going with Pioneer check maybe they make one. I got a Kenwood CCD-900 camera. It plugs right into the back of my Kenwood DNX8120 head unit.
__________________
'07 Tahoe LT2 5.3L / K&N CAI / Flowmaster Dual Exhaust / Kenwood DNX8120 / JL Stealthbox
Old 10-29-2009, 10:39 PM
Quote:
I don't think it's really GM's fault. It's just the options are more advanced now. Even though the head units themselves may not be that advanced when you add Onstar, steering wheel contols, satellite radio, bluetooth, etc..
I've replaced the radio in just about every car I've ever owned and did them myself and had every intention of doing the same with my Tahoe but when I saw the different adapters and all the wires, I said "hell no!!"
__________________
Old 10-30-2009, 07:15 PM
you cannot disable the door chime without losing either all other audible warnings, or losing the auto dome light feature.
as far as a factory camera goes, check out this thread, you can get a factory looking appearance for a quarter of the cost
__________________
Tags
2004 , bose , chevrolet , chevy , chimes , colorado , factory , forum , head , radio , replace , replacement , silverado , suburban , tahoe , unit , warning
HTML code is On
