07 Tahoe Instrument Light Problem
Old Jul 3, 2009 | 3:31 PM
paradisepatiosAZ's Avatar
Default 07 Tahoe Instrument Light Problem
I have a 2007 Tahoe LT that the instrument lighting suddenly quit working. The info center & odometer work. Also the two over head map lights don't work unless the dimmer **** is cranked all the way to the on position then you can toggle them on and off. Also I found that the headlight control **** pushes in and out. Is this normal...?
Sorry for so many questions but I'm stumped!
Old Jul 4, 2009 | 10:22 AM
Bump to the top... No suggestions?
Old Jul 6, 2009 | 3:42 PM
bikerdude's Avatar
I once had the problem with the headlight **** that seemed to want to "drop back" into the dash. I pulled gently on it to re-seat it.
Perhaps your problem is the headlight *** has come unseated somhow.
Old Jul 8, 2009 | 8:17 AM
welchy's Avatar
I have the same problem going on in my 08 tahoe right now
Old Jul 8, 2009 | 8:19 AM
HotSauce6226's Avatar
Impala Super Moderator
Check you back up lighting fuse
Old Jul 8, 2009 | 11:39 AM
SabrToothSqrl's Avatar
Default 07
07 should still be under warrenty, no?
tekniq
34
Jul 4, 2022 1:26 PM
Mike8283
Sep 29, 2013 9:23 PM
Zach27911
Mar 8, 2013 1:04 PM
beckya99
Jul 12, 2011 12:29 PM
jim43bob
Sep 27, 2010 2:46 PM
