Front Brakes 1992 G30 1 ton van
Old Jul 15, 2009 | 5:41 AM
2Tfun's Avatar
Question Front Brakes 1992 G30 1 ton van
Have a problem with brakes pulling to one side. Replaced pads and scuffed rotors (not warped nor grooves). Based on the mounting design, can not tell how the calipers are suppose to "float" to allow to be even spaced over the rotor thus allowing the pads to have equal pressure and adjust for wear.
Thanks,
Pat
Old Jul 31, 2009 | 4:54 PM
stewdogg's Avatar
Sounds like you need to clean and rebuild the calipers... the adjuster pins are probably seized causing the pull to one side.
Thanks,
Pat
Old Sep 29, 2009 | 4:04 PM
2Tfun's Avatar
Thumbs up
The front brake calipers don't have slider pins. There are a Bendix design with v -channel at each end.
The problem was a collasped brake hose from the hard line to the caliper. Replaced the hose an no more pull.
truthstar
Jul 27, 2021 4:19 AM
89silverado283
Feb 16, 2010 8:50 AM
nycac
Sep 16, 2009 5:02 PM
montana chevy guy
Aug 14, 2009 2:41 AM
