4x4 problem
Old May 26, 2005 | 12:10 AM
02Z71's Avatar
Default 4x4 problem
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
SymRealOnLoad = window.onload;
window.onload = SymOnLoad;
I have a 2002 Z71 and now when I switch to 4wd, the service 4WD light comes on and I can not switch back to 2wd without turning the Tahoe off. When I start it back up, I can then switch back to 2wd. Can suggests on the problem and possible solutions?
Old Jun 17, 2005 | 12:43 PM
Jeff's Avatar
Default 4x4 problem
Chevrolet has had problems with the four-wheel drive switch. You might try replacing the switch to see if that will fix it. Switch is relativly cheap from the dealer
Old Aug 12, 2008 | 7:31 PM
haulinoats's Avatar
Default RE: 4x4 problem
Ive found I have to throw it in nutural and be going like 5-10 mph for it to pop out of 4wd, especially out of low.
technicauto
May 4, 2011 5:14 PM
chevyman1978
May 1, 2008 6:41 AM
99silver
Feb 2, 2008 4:14 PM
cowboyfromhell
Jun 5, 2007 9:31 AM
partsfor24
Apr 18, 2007 3:55 AM
