S-10 & Blazer 1982-2005
Old Jul 22, 2015, 10:21 AM
Browse all: Brakes
Parking Brake
Old Jul 26, 2009 | 10:40 PM
a. palmer jr.'s Avatar
Default Parking Brake
I have a 1998 S-10, up until recently the parking brake worked fine, but now the brake won't stay on after I push the pedal down. It works fine while the pedal is down but when I take my foot off the pedal it quits working. I've jiggled the release handle and tried pushing the pedal down harder but to no avail. Any ideas?
Old Jul 27, 2009 | 9:46 AM
far2grumpy's Avatar
I've attached service manual extract for replacing the parking brake assembly ... not because I think it needs to be replaced but to give you an idea of the mechanics of the device.
I'd take a look at the brake release hardware ... best case - it might just need lube. Worse case - could be something stripped or broken.
Get in touch if you need any of the procedures referenced in document.
Good luck!
File Type: pdf
Old Jul 28, 2009 | 7:38 AM
Thanks for the PDF..that was really helpful! If it's not too much trouble could you please get me the 2nd item instructions, Closeout/Insulator Panel Replacement-Left. It might be helpful to know how to remove the cover, just in case. I think I'll try to lube it first, I don't know how it would have worn out or stripped anything..it hardly ever got used.
Again, thanks
Old Jul 28, 2009 | 11:12 AM
far2grumpy's Avatar
Again, thanks
I don't recall having a PB pedal that wouldn't latch down. Not much to go wrong there ... with luck the cable is binding and just needs a shot of a good quality spray lube (I'm partial to Slick 50 spray for staying power but I suppose they're all about equal).
Drawing's attached ...
File Type: pdf
kaptain howdie
Dec 16, 2014 8:20 PM
aahzmandius
Apr 2, 2011 4:39 PM
LouisT
Nov 13, 2006 6:54 PM
Greg O
Sep 8, 2006 2:21 AM
akadeno
Aug 24, 2006 12:58 AM
