05 express 3500 a/c belt woes
Old Jul 31, 2009 | 6:11 AM
jdbeck's Avatar
Default 05 express 3500 a/c belt woes
hi folks!
I have an 05 express 3500. 22K miles.
appreciate any tips on how to solve this:
About 1 yr ago, I snapped an a/c belt. so I replaced both belts, main and a/c and the a/c tensioner. (it was a bit wobbly ) .
Lost another belt 6 months later.
Now 2 more belts in 4 months this spring.
The pulleys look great. no sign of a gouge or burr.
My only clue is that occassionally, the van makes a noise in the rt front under acceleration that sounds like a guy with an impact gun beating on a stuck nut.
The van is more likely to snap a belt on a warm start. ie - drove to grandma's. inside for 1hr or so, then start up. wifey has lost the belt 2 times in that scenario.
my guess : too high pressure in the a/c causing compressor to chatter. but I gotta be sure before tearing into that beast.
Thanks !
jeff
Old Jul 31, 2009 | 4:08 PM
stewdogg's Avatar
So is the belt snapping within a second or so after startup or is it smelling like rubber before it snaps (and takes a min or so)? It sounds like it could be some pullys out of alignment.
If you suspect the ac compressor of being the culprit then you could pull the compressor/ac relay to stop the compressor from kicking in. When the compressor turns on does it make any kind of grinding noise?
Originally Posted by jdbeck
hi folks!
Thanks !
jeff
Old Aug 1, 2009 | 5:52 AM
jdbeck's Avatar
No burning rubber smell. mainly the problem happens on acceleration. like pulling out from the driveway, or a parked position. the 'impact gun' noise happens then. (but not on a regular basis, which is why this is a bugger to track down.) Switching off the a/c stops the 'noise' . Could it be the a/c clutch or maybe belt slap?? The damaged belt looks as if someone pulled it apart. They snap across the width of the belt cleanly, with a few fibers visible. sort of like putting the belt to a stress test. No griding from compressor normally. Obviously, i can't tell if it is grinding while driving. But up on ramps, no belt on, the pulley rotates freely and smoothly.
Old Aug 4, 2009 | 10:57 AM
stewdogg's Avatar
Does the A/C work? Sounds like a stuck a/c compressor to me. I wonder if the "impact" sound is the belt jumping the a/c pulley because it won't turn?
landon101
22
Nov 14, 2021 10:48 AM
Screamingson
Dec 30, 2012 1:20 AM
Got Options?
Dec 17, 2012 6:09 PM
OtherCarASaab
Aug 31, 2012 12:00 AM
hollijb
Feb 12, 2007 12:21 PM
