75 Chevy C10
Old Aug 1, 2009 | 6:44 PM
danwilko17's Avatar
Default 75 Chevy C10
So need to replace my turn signal indicator sometime this winter, and hoping to get some advice, or guidance to do so or a quick fix..
When I go to turn it on there is a sweet spot that it will turn my blinkers on.. right turns i have to hold it there and left turns it clicks and holds if you know what i mean.. Anyways thinking i will replace it over the winter and hoping to get some advice now so I'm not leaving it to the last minute..
Guessing I need to remove the steering wheel and then take off the column collar with the ignition and signal indicator out.. after that.. well I am going to play it by ear unless i get some advice, Thanks
Old Aug 1, 2009 | 7:31 PM
old dog's Avatar
Default signal
i believe you will need a loc plate snap ring remover ,cal van makes them every body sells them .hers one http://www.sjdiscounttools.com/kd2414.html
isaac_22
Dec 26, 2007 9:23 PM
w_houle
May 10, 2007 7:47 PM
sullivan_joshua
Feb 10, 2007 9:02 PM
mute_voice
Jan 16, 2007 7:23 PM
