1995 Chevy Silverado 1500, 305 V8 Stalling
Old Aug 4, 2009 | 10:40 AM
natemclain's Avatar
Default 1995 Chevy Silverado 1500, 305 V8 Stalling
Engine Performance problem
1995 Chevy V8 Two Wheel Drive Automatic 175000 miles
'95 Chevy 305 V8
Truck idles in Park & Neutral just fine.
The truck cuts out and stalls after stopping.
Several things have been replaced.
Throttle Position Sensor
PCV Valve Distributor & Rotor
Fuel Filter
Spark Plugs
We have checked everything simple so far. We are leaning toward the fuel pump but we want to check the pressure & pressure regulator. There is no way to check the pressure. There is one fuel line and a return line.
Can someone explain how you check the fuel pressure?
Surely there is some trick that the dealership or a technician does to check the fuel pressure?
I'm leaning towards cutting the rubber part of the fuel line and installing a "T" and connecting a fuel pressure hose/gauge to check and see whats going one before buying and changing the fuel pump.
Any tips?
Nate
Old Aug 4, 2009 | 10:46 PM
lukemoore646's Avatar
there is an adapter that goes in place of the fuel filter or look back at an older thread about tbi
87caprice718
Jul 29, 2015 5:16 PM
canadian33
Sep 28, 2013 6:49 PM
jrobpush
Mar 22, 2013 10:37 AM
rmac1100
Oct 10, 2012 1:19 AM
