Platform: Delta
Also Check out ChevyHHR.net
2006 Chevy HHR Serpentine Belt
Old Aug 8, 2009 | 9:36 AM
amazing1rpk's Avatar
Default 2006 Chevy HHR Serpentine Belt
I have a 2006 Chevy HHR with the 2.4 liter engine. The serpentine belt shredded off on a trip to my parents. I got it to their place OK but of course the battery is done for and won't charge. I bought a new belt, looking for how to get it back on. Any tips? diagrams? I am a computer guy, not a mechanic. Thanks
Old May 27, 2022 | 2:41 AM
HHR guru's Avatar
Default Belt tensioner
You need a flat wrench available at any auto parts. It is flat with a welded head of 3/8. There is a slot that it goes in, right in the middle of the tensioner. With this tool, you can install or remove a belt. It cost about 15 to 20$.tel them you need a serpentine belt tool for an hhr
Old Jul 8, 2023 | 12:41 AM
HHR guru's Avatar
on the belt tensioner, there is a square hole for a special wrench, its flat and has a fixed 3/8 headlike the head of a ratchet
This particular wrench is for a ford, but identical to the one you need, less the head size.hhr uses 3/8, ford uses 1/2
they are about 15 to 20 dollars at autozone,. You will not be able to complete the job without it.go at it from the passenger wheel side..also to make your belt last infinitly longer, soak it in Armor all,original formula, for about 10 min and then dry it off and install it. it changes the structure of the rubber and you can get 140000 miles out of it,at least
Lakeman 903
Nov 27, 2021 2:19 PM
Tammyjo
Sep 14, 2017 7:54 PM
AzraelFish
Astro
Jul 6, 2010 6:16 PM
Steelo
Dec 14, 2009 9:35 PM
ButchA
Jan 8, 2007 7:00 PM
