Go Back   Chevrolet Forum - Chevy Enthusiasts Forums > Chevy Vans & Minivans > Venture
Old 08-11-2009, 02:29 AM
grejohn grejohn is offline
Default Problem starting Venture '97
My van just stop starting. It got me stalled on the road. The engine just stopped suddenly. When I tried to start it, it wont. I dont hear the Fuel Pump humming when I turned the key to ON position though the engine is cranking when tried starting it. I changed the fuel pump, fuel pump relay and fuse but with the same result. Still, I think the fuel pump is not pumping gas or doing its job.
What else could be the source of the problem why it is not starting??
HELP please!
Old 08-12-2009, 08:26 PM
tuffy tuffy is offline
1997 Oldsmobile Silhouette
If your sure it is a fuel problem, check the connector under the van, behind the drivers seat they have been know to corrode causing the fuel pump not to work.
Old 08-21-2009, 11:06 PM
Quote:
thanks for your reply.
i checked the wire harness going to the fuel pump but it looks good and not corroded. the continuity is okay when i checked it. how much voltage should i get from those wires? other than the wires and fuel pump... what are the other issues that i should check, still not starting.. i still dont hear the fuel pump humming when i turn the keys.
more help please!
Old 08-25-2009, 07:24 PM
update with my problematic van...
i replaced the fuel pump again with an original chevy part because one mechanic told me to do so. but the problem was not solved. it started though for a couple of minutes but died. i noticed that the pump is intermitently pumping gas that's why the engine die after few minutes. i ruled out that the pump is not the problem, but a device that gives signal to the fuel pump to pump gas. my question now is.. what device is it?? is it the EGR or the PCM as what i saw in some forum.
this is a challenge for me.. but i need someone to HELP to pinpoint the real culprit!!.
PLEASE HELP!!!
Old 10-02-2009, 01:44 PM
Javier Javier is offline
Hi grejohn
I'm new to this forum, and got into because I have the same problem with my Venture 97, 5 diferent mechanics have gotten their hands into the motor and the problem still remains, all of them concluded that the ECU got a failure, so went to the autoparts store and ordered one, after being installed the problem remains, so I wonder if you got yours fixed already and what was the solution to your problem, it's posible the same case I'm in front of.
thanks for any advice
Old 10-12-2009, 02:02 PM
Quote:
Originally Posted by Javier View Post
Hi grejohn
hi.. sorry for late reply.. but i sent my venture to a mechanic since I can't fix it myself. They said it's a bad ECU and they replaced it. So far it is working now. This van cost me a lot already with all the problems it brought me. I hope it will last for another 6 months after that I want to junk it already.
Now my tail light is not working... and it's a electrical wiring issue. Don't know where to trace the problem.
Hope you can fix yours.
Tags
95 , 97 , access , camaro , chevy , ecu , fuel , panel , problems , pump , start , starting , stop , van , venture
HTML code is On
