Go Back   Chevrolet Forum - Chevy Enthusiasts Forums > Chevy Cars > Camaro
Old 08-15-2009, 08:41 PM
Kevie Kevie is offline
Default '81 Camaro making an odd noise
At about 1500+ RPMs Im getting a rattling like noise thats sounds like its coming from the trasmission, Thought maybe the bolts on the flywheel had backed out and were loose, but thats not looking to be the problem. It will make the noise in park, or any gear as long as its above 1500 RPMs. Any ideas? Register today for free or log-in if already registered to remove this ad!
Old 08-16-2009, 03:08 AM
suzuki-guy's Avatar
suzuki-guy suzuki-guy is offline
General Discussion Moderator
1995 Chevrolet C/K 1500
Could be your cat converotr needs replaced get under it while someone else revs it up and see if you can isolate the noise. By the way welcome to the forum!!!
__________________
1995 Chevy K1500 355 5 speed manual 4:56 gears 35"tires
Old 08-16-2009, 06:19 PM
Turns out its coming from the motor, it's a main bearing
Old 08-17-2009, 01:02 AM
Ride of the Month
April 2009
2000 Chevrolet Blazer
My Garage
Main bearing... that sucks man.
Quote:
Easier said than done.
And yes, welcome to the forum fellow 81 owner!
Old 08-17-2009, 09:57 PM
ExcessiveEgo ExcessiveEgo is offline
my camaro makes the same noise......... but only occasionally, i was thinking it was the cat as well, i hope its not the engine........ how many miles does yours have out of curiosity?
Old 09-07-2009, 12:58 AM
Quote:
Sorry I was gone so long, I was out of a computer for awhile
My odometer is messed up so I am not sure, the motor is a rebuilt though, with roughly 1k on it, thats why I figured it may have been a main from not wearing it in properly, but people ive talked say it most likely is a cracked flywheel, it will look fine just looking at it, but once you get it spinning it will start rattling, so my next step is to pull it out and actually see if its cracked. I really hope its a cracked flywheel and not a main.
Old 09-07-2009, 07:22 AM
mudmaniac's Avatar
mudmaniac mudmaniac is offline
Ride of the Month
May 2009
1987 Chevrolet K Blazer
My Garage
I would double check the cat like Suzuki-Guy said, is it a rattle or a knocking noise?
I had a knock that made me convinced that I had spun a rod bearing so I dropped the pan and replaced them all just to find it was the cat after all. Sure is easier than changing the main.
__________________
MudManiac
95 Tahoe 383cu.in./350hp/425ftlbs
6" lift 16x35x16 Boggers
Old 09-07-2009, 06:28 PM
Thanks for the suggestions, now I've got a few more things to check before I jump to replacing a main.
Next step is to find the time, been quite busy lately
__________________
'81 Camaro Z28
327 Block 305 Heads
Edelbrock Intake and Carb
T-Tops
Old 09-10-2009, 02:22 AM
jerseymike68 jerseymike68 is offline
Thank You!
Old 09-30-2009, 09:02 PM
RixZ-28's Avatar
RixZ-28 RixZ-28 is offline
Send a message via Skype™ to RixZ-28
I think I had the same kinda noise from my Caprice....it turned out to be the flex plate (AKA....flywheel). Couldn't "see" any cracks until I pulled the tranny...the freekin thing was covered in spider cracks....it now resides on my wall....it's quite a conversation piece...when you put a light behind it...it's QUITE something!
If it is the flex plate...get it replaced ASAP.....the bugger can shatter under load....not pretty!!
__________________
THE KILLER TOMATO!!
ZZ-4 powered '79 Z-28
Rick K.
'79 Trans Am
"Sir Viver"
(only 32k original miles!)
'91 Caprice LTZ
"Sophisticated Rudeness!"
(May you rest in peace old friend!)
'98 SUPERCHARGED Regal GS
"My Daily WHEEZER!"
(I'd rather be BLOWN than juiced anyday!!)
Tags
305 , 81 , camaro , camero , forum , knocking , make , makes , making , noise , park , rattling , sound , started , suburban , ttop
HTML code is On
