TrailBlazer 2002-2009
my fuel guage is not working
Old Aug 19, 2009 | 11:53 AM
rbrito24's Avatar
Default my fuel guage is not working
i was wondering wat i need to have replaced on my 03 trailblazer. ive heard that i need to change my fuel pump and also heard fuel level sensor. so im wondering which one is causing my fuel guage to always read "E"
Old Aug 20, 2009 | 12:56 PM
rbarrios's Avatar
You have an 03 like me...
I have noticed that the early TB's if the needle marks E... many times its due to sulfur buildup in the tank..
later models like 05 and up- had a slightly different fuel level sender that did fail.
In your case.....
Try a bottle of techron fuel system cleaner. Use techron-- not some other brand....
This has stuff to clean the sulfur and help the fuel level sender begin to read correctly...
If it still fails to work-- then it will be time to change the fuel level sender....
BUT if you have high miles--- you may as well swap out the fuel pump since you have to remove the tank to get to both-
Here in Los angeles... at 133,000 miles I changed out my factory pump. (The level sender and fuel pump worked fine- I just wanted to change it before it failed on me somewhere in the middle of mexico- as I was taking a trip down there at the time).
Total cost with pump and stuff was about $330.
I called a local dealer to ask how much they charged for this same job.. I was quoted about $1200.
so try techron- and if not-- then try the fuel level sender swap--- or the pump and level sender as a whole..
I have seen 1 case--- where an owner of a TB- changed the sender and pump-- and the needle was still off...
in his case--- he had a bad stepper motor in his dash....
silverado 1500 2001
Aug 25, 2014 9:40 PM
strictly chevy
Nov 2, 2009 2:05 PM
lisavictoria
Jun 5, 2009 5:56 PM
04impala
May 1, 2007 1:55 PM
blazinblazer
Dec 16, 2006 6:44 AM
