S-10 & Blazer 1982-2005
1994 s-10 blazer
Old Jun 2, 2005 | 10:41 PM
Loancheetah's Avatar
Default 1994 s-10 blazer
I recently had to change the alternator out and shortly after doing so it decided to start giving me a hard time.I had difficulty getting it started and then after a few miles the tach would start spiking and then the motor would stutter and leave me stranded shortly there after. I then replaced the coil and an ignition module located on the coil mount, this work for 2 days and then it began again.I was told that Chevy's use a ballast resistor limiting incoming coil voltage to 8 volts. Does anyone know if that is true?
habamock
Mar 12, 2008 4:55 PM
94blazerz
Jan 31, 2008 1:45 PM
pfsantos
Jul 24, 2007 2:07 PM
katievp
Nov 24, 2006 5:27 PM
