Jerky movement when shifting a 5 speed
Old Sep 10, 2009 | 3:24 PM
jiggsy's Avatar
Smile Jerky movement when shifting a 5 speed
Hi all,
My truck "jerks" after I've shifted gears and the clutch is out. Either 1st to 2nd or 2nd to 3 and so on.
It feels like the bushings to the leaf springs are soft and the diff wants to keep going around. It's been doing this since I bought it and never really paid attention to it but it's starting to get a bit worse.
The previous owner used to have a camper on it.
Is there a known issue for manual transmission trucks? Could it be in the transfer case?
Those of you about to ask about my driving abilities....I used to drive semi's for a living and am a qualified driver instructor. So plz refrain from those comments
Any help and suggestions will be greatly apreciated.
Old Sep 10, 2009 | 6:15 PM
Originally Posted by jiggsy
Hi all,
you wont get no bad comments here my friend...but some questions
what year truck are you rolling?what t-case etc...im assuming the tranny is in the nv family...yes when trailers are on as you know it puts alot of wear on rearends,bushings,trans,etc......
Old Sep 10, 2009 | 10:18 PM
lukemoore646's Avatar
i would check check your transfer case/ tranny mount, it could be loose, I had a guy bring a semi tractor in for a service and he wanted me to check the fifth wheel cause the truck jerked around, while checking u-joints i noticed i could move the front drive axle alot by hand because the torque arm bushings were gone, it really jerked while bobtailling
Old Sep 11, 2009 | 12:01 AM
therewolf's Avatar
Won't cost nuthin' to take a close look at your U-joints, trailering heavy loads tends to tear them up.
Count yourself lucky if it is the U-joints, all things considered, they're cheap.
Just grab the driveshaft and give it a rigorous twist and shake to see if there's any free play.
Old Sep 14, 2009 | 10:48 AM
jiggsy's Avatar
Thanx for the replies.
The truck is a 2000, 1500 silverado regular cab,4X4.
It's got the 4.8l Vortec with the 5 speed.
I don't know for sure what the model numbers of the tranny and transfer case are.
Are they written somewhere?
As far as the U-joints, I did indeed check all of them. The truck was off it's wheels. There doesn't seem to be any looseness.
If the tranny mounts were loose, wouldn't I see the stick shift "move" alot when I accelerate/slow down?
The truck didn't tow any trailers, it was an inbox camper that the previous owner used.
Thanks a bunch !!!!
Old Sep 29, 2009 | 6:35 PM
dunhamr's Avatar
The first thing I would check is the U-joint and slip yoke. Shifting into any gear and a jerk occurs could definately be a bad U-joint or slip yoke.
I don't think it would be your trans mounts. If it was you would be having a hard time shifting ino certain gears.
futurewave
Sep 17, 2011 9:26 AM
alxwilhelmi@aol.com
Jul 20, 2011 8:32 PM
stephschevy
Feb 6, 2010 10:59 PM
sunshine219
Jan 8, 2009 7:28 PM
sgtp
Dec 1, 2007 1:08 PM
