Need work diagram - Silverado Heater Core
Old Sep 16, 2009 | 12:11 AM
db 183's Avatar
Default Need work diagram - Silverado Heater Core
Turned on my heater today (first time in months) and the smell of antifreeze was overwhelming. Windows all steamed up.
After lots of searching, I finally pulled the black plastic cover from around the heating components under the dash board. Antifreeze leaking pretty good under there.
The problem is, after pulling off the cover and the lower right half of the dash board including the glove box, I am not sure how to get to the heating core to see what is leaking. Is it a hose or is the whole thing in need of replacement. And if so, how the heck do I replace it?
If anyone has a job diagram, I would appreciate it.
It is a 2000 chevy silverado 1500ls, 5.3l engine, 4wd
Old Sep 16, 2009 | 10:13 AM
Mike Sigmond's Avatar
ROTM Coordinator
Default Here is what my book says on your vehicle
To Remove:
  1. Remove the HVAC assembly.
  2. Remove the heater core cover screws.
  3. Remove the heater core cover from the HVAC assembly.
  4. Remove the heater core gasket from the core.
  5. Remove the heater core from the HVAC module assembly
To Install:
  1. Install the heater core to the HVAC module assembly.
  2. Install the heater core cowl gasket to the HVAC module assembly.
  3. Install the heater core cover and screws to the HVAC module assembly.
  4. Install the HVAC module assembly to the vehicle.
I hope this helps.
Old Sep 18, 2009 | 5:21 PM
db 183's Avatar
It turned out to get to it, I had to take the whole dash out. That was not fun.
jerry_bas
Feb 27, 2015 4:28 PM
HHR Ratt
HHR
Oct 22, 2010 9:14 AM
Kegger
Dec 16, 2009 8:50 AM
masterbenztech
Jul 28, 2007 8:58 PM
Gzcaster
Oct 6, 2006 9:54 PM
