I want to change the rear end in my El Camino with a posi with disc brakes. Does any one have any suggestions on what may work? It has a 350 with a 700r4.
Thanks for the help
hey earlie,it's just a suggestion but what about looking for a rear from a chevy 4x4 with a 12 bolt and posi,if it doesn't have a posi fairly easy install....as for disk brakes you could either find another axle completly setup with disk or do a conversoin to disk on the 12.....where in ca are ya?...red
ahhh if you were only closer.....im nor cal and there is one with a new posi and a fresh rebuild in my garage with 3:73's.....red.....good luck with the search
mmmmm new gears(it's not the same axle as in the sig(10 bolt garbage)
