Platform: J-body
car runs rough after tune up
Old Sep 19, 2009 | 2:01 AM
amarchwinski's Avatar
Default car runs rough after tune up
Hello,
My car started running rough, now my car had a big hole in the muffler so I thought that might contribute to the issue so I replaced that. That didn't seem to work, so I took it up to Autozone and had them run their simple code check and it said I'm having a misfire and knock sensor error. Now few months before this I had a head gasket replaced and I had my check engine lite come up after wards and my crank position sensor had an error, but my car never ran rough or had problems starting, so I ignored it. The light stayed on, no big deal, now it flashes. I replaced wires and spark plugs and still running rough. Plus after getting the muffler it runs kinda loud still. When I give my car gas it seems to lack power and takes awhile to get up to speed, but still safe to drive. Any suggestions what it is before I take this to a mechanic and get charged $900?
Thanks,
Tony
PS. My car doesn't stall out or even come close to doing so.
Old Sep 25, 2009 | 11:13 AM
Siliconasp's Avatar
Sound like a valve issue, complicated by a failed Knock sensor and crank position sensor. I would have a simple compression test run on the cyclinders. this will help narrow down if a valve was damaged or messed up when the head gasket was replaced. Also this time when you have it repaired, have them replace those 2 sensor.
buster
37
Aug 15, 2022 5:21 PM
fjdavid
Dec 13, 2015 10:25 PM
Jeremy3040
Mar 23, 2014 7:34 PM
rbeadles
Feb 27, 2011 8:34 PM
