New Radio in '08 Silverado
Old Sep 24, 2009 | 7:07 PM
Maverick0984's Avatar
Default New Radio in '08 Silverado
I'm wanting to replace the radio with a nice 7" screen of some sort. I've already got a handle of what type of radio and the harness's and such necessary but I cannot for the life of me figure out how to get the radio out. Is there any documentation or anything anywhere that would point me in the right direction? I assume after I get the first layer of plastic on the exterior of the dash it will all be down hill from there, but not sure how to go about that.
Old Sep 25, 2009 | 2:35 PM
QUETRANPA's Avatar
hi, look i have an '07 silverado and i'm in the same prosses, i have the navigation sistem in the truck now (it is still locked up but i'm working in to unlock it and i got help in this site just a minut ago) so to take off the factory radio was really simple, really you just remove the plastic panel and you have access to 2 screws in front of the radio, remove them and you'r done.
Old Sep 26, 2009 | 11:11 AM
I am looking for a little direction on how to remove that plastic panel. It is pretty big and I don't want to break anything. This is an example of what my dash looks like.
I have seen 2 slightly different dashes floating around. This one, (like mine) and one with a much smaller dash piece that gets removed.
Old Sep 26, 2009 | 7:31 PM
Remove the drivers knee bolster, (2 phillips and a 10mm bolt), remove the panel right next to it, (2 7mm bolts), then, starting at the upper right corner, grab the dash above the vent with your fingers(or a plastic pry bar if you're not strong enough =), and just pull. Work your way around the topthen down along the shifter. Its all clips.
When putting it back, the upper left corner of the panel can be a bugger as it kind of goes underneath the dash. I uaully push the vents in, then take a plastic prybar to pry the corner under the dash and then just hit the rest back together.
adamant
Feb 15, 2009 8:49 AM
mfinley
Jan 21, 2008 11:31 AM
guvner
Jan 7, 2008 4:16 PM
