2005 Suburban Battery Drain
Old Sep 29, 2009 | 7:56 AM
bigdaddyviking67's Avatar
Default 2005 Suburban Battery Drain
I have a 05 Chevy Suburban that has a overnight battery drain problem. I replaced the battery and the alternator is charging fine. Recently I disconnected the rear hatch actuator because it is weak and wouldn't unlock the hatch. I taped up the lose connector. By having this disconnected, could that be the source or problem with my battery draining over night?
Old Jun 26, 2017 | 1:47 PM
PABLOZ's Avatar
Default same problem d
Did you
ever find the problem? I am thinking ignition switch
Old Jun 26, 2017 | 2:07 PM
Unlikely that a weak actuator would cause a battery drain as it only draws power when the button is pushed!
Old May 13, 2019 | 4:13 PM
JTB Eagles's Avatar
2007 Suburban 1500 - Low beams aren't working, high beams do. Sometimes the radio won't turn on, sporadically the battery is dead. Will start right with jump pack attached.
Old May 14, 2019 | 10:38 AM
MrRenoman's Avatar
I had a problem with my 2001 Suburban battery draining. Found out it was the radio amplifier that wasn't shutting off. In my case it was in the under hood fuse panel. I ended up putting in a small relay in the available space in the fuse box and wired it to switched power from another switched fuse in the same fuse panel. The relay would open the radio/amp circuit when the engine was shut off. Removing the radio/amp fuse might be a good way to check this theory. It could be something else but in my case it was the radio amplifier.
Art
JPTL
Jul 15, 2024 4:19 AM
funnyguyMI
Mar 10, 2024 9:31 PM
garyd
Apr 24, 2016 3:04 PM
mlgunkel
May 13, 2013 6:59 PM
birdxa
Sep 30, 2007 2:45 PM
