Mode actuator stuck in defrost mode.
Old Oct 12, 2009 | 6:48 PM
mummp's Avatar
Default Mode actuator stuck in defrost mode.
After jumping off my truck from a dead battery, my mode actuator only works in the defrost mode. I have tried the recalibration methods with no luck. The truck is a 2004 silverado with the single zone control. The temperature works fine as well as the fan speed. The recirculate button also works. I would appreciate any help trying to get this fixed.
Thanks,
Philip
Old Oct 13, 2009 | 5:31 PM
desrtrat's Avatar
try disconnecting the negative cable for about 1 min. then hook it up and try again. had to replace my battery in my 03, and same thing happened. worked fine after
good luck
Old Oct 13, 2009 | 8:48 PM
mummp's Avatar
Thanks for the reply, unfortunately I've tried that already. I left the battery off overnight. Since it looks like I'm going to dig into the dash, what components should I focus on? Are there any other options before I dig in?
It seems that the "stuck in defrost mode" issue has been addressed before, but I have not found a posted solution. Any help on this ? ?
skategranger
Feb 18, 2013 2:38 PM
EagleEye82
Feb 21, 2012 3:02 PM
max2413
Jul 1, 2010 4:18 PM
jmz
May 2, 2010 5:13 PM
SJohnson
Sep 4, 2009 6:52 PM
