4.3l to a 305/335 Swap
Old Oct 15, 2009 | 10:02 PM
rhyno430's Avatar
Wink 4.3l to a 305/335 Swap
Just wondering what it would take to swap my 4.3l v-6 from my 92 chevy k1500, with a 305/335 engine that i am building.
The 305 is from an older camaro (84)
Further information: I do not care what you think of the 305/335, all i want to know is what it would take to swap it with my 4.3l, I understand that a 350/383 is a better engine but i already have the 305, and i like to do things that other people shy away from.
In advance, Thanks everyone.
Old Oct 16, 2009 | 6:09 AM
mudmaniac's Avatar
Ride of the Month
May 2009
Are you planning on going with fuel injection or a carb?
Old Oct 16, 2009 | 12:13 PM
rhyno430's Avatar
I am planning to go Carb. It is TBI right now.
Old Oct 16, 2009 | 5:31 PM
mudmaniac's Avatar
Ride of the Month
May 2009
OK carb, then you will be installing an ignition system in place of the computer.
Check the trans and make sure it's not electronic as well.
Old Oct 16, 2009 | 9:50 PM
rhyno430's Avatar
oh i forgot to even mention that...
the truck is a W/T trim, and it has the 5 speed manual, which if i'm correct should be the 700r
Old Oct 17, 2009 | 7:39 AM
mudmaniac's Avatar
Ride of the Month
May 2009
OK, sounds like it will work to me, you may need a fan shroud from a V8 model.
One thing I don't know is how the motor mounts will line up, maybe someone else can chime in.
Old Oct 26, 2009 | 2:40 AM
chadwick's Avatar
I have a 89 gmc sierra that originally had a 4.3 tbi, and its got a 5 speed manual (HM 290) and I swapped it with a 350 tbi. The only things I had to change was the engine mounts, clutch, flywheel, and remove the fan shroud. I put an electric fan in so I dont need a shroud and removed the mechanical fan. This makes for more room too in front of the engine. I even kept the same radiator, ecm, rad hoses, all of the wiring is the same. But if your going carb you dont have to worry about the sensor harness.
Not sure about a 305, but the 350 flywheel is thicker than the 4.3, and the clutch too. Everything bolted up nicely, just need to buy V8 engine mounts, and the mount brackets that bolt to the engine.
Ive had no problems with the trans or any driveline part, not even a check engine light on. The trans is holding up good still even after several burnouts and off roading.
87caprice718
Jul 29, 2015 5:16 PM
reesecotey
Jan 6, 2009 10:51 AM
norcalrider
Nov 15, 2008 12:45 AM
sally
Jul 29, 2008 7:38 AM
