express 3500 front passenger seat
Old Oct 18, 2009 | 8:16 AM
peaceridge's Avatar
Default express 3500 front passenger seat
Has anyone removed this and the box it sits on? I'm buying a 2008 and would like to remove it to put in dog crates. Any help would be most appreciated.
Kirra
Old Oct 18, 2009 | 8:09 PM
Remove the 4 bolts and d\c any electrical connectors
what do you mean "the box it sits on"?
Old Oct 19, 2009 | 2:43 PM
peaceridge's Avatar
Thanks for such a quick reply. I guess I should have clarified. I'm getting a Pleasure Way that is built on the Chevy Express - PW must put in the box that allows the seat to turn around. I thought it was a Chevy thing.
Do you know if I disconnect the electrical connectors (assuming PW hasn't done anything irregular under there), will it cause a problem with anything? I ask because I currently have a Honda Element and if you take out the passenger seat, ALL the airbags are disabled, not just the passenger one - so the seat can't be removed.
I'm going to also ask the PW factory if they have done any electrical things under there.
Again I appreciate your answer - I'm a real nooby about vans.
Kirra
Old Oct 19, 2009 | 5:04 PM
do you have a switch on the dash to disable the passenger airbag? or is there a pasenger presence system?
If there is a switch on the dash, then you should be able to remove the seat without a problem and just turn the airbag off
Old Oct 20, 2009 | 8:44 AM
peaceridge's Avatar
>If there is a switch on the dash, then you should be able to remove the seat without a problem and just turn the airbag off<
perfect! I'll check - thanks so much!
goyakpacking
37
Jan 27, 2024 2:01 PM
mp2140
13
Jul 27, 2019 8:16 PM
Davidc21a
May 8, 2018 7:29 PM
LeeHamilton
Oct 26, 2014 9:49 PM
JeremyLembo
Mar 9, 2011 12:46 AM
