A/C Cyling all the time
Old Oct 18, 2009 | 10:13 AM
ristpin's Avatar
Default A/C Cyling all the time
I just bought an '04 Silverado, 5.3. The A/C compressor cycles even with the control turned off!! I'm taking it back to the seller tomorrow, but want to be a little educated as to the cause. I'm thinking just a bad switch? Any body have/had the same problem? Thanks.
Old Oct 19, 2009 | 11:40 AM
cams 98 silverado's Avatar
all new a/c systems on newer vehicles have the compressor cycling all the time. when you are either using the a/c system for cooling cab or defrosting, the difference between new and old is old compressor cycles on and off. newer ones are on constantly. thus the reason for such a massive puddle of water condensation being generated by newer a/c systems. as for the compressor being on even when your not using the system. IE- fan is off, defrosting is off, cooling is off and its still cycling... does your a/c work. does it defrost fine? any noises when compressor engages/disengages? if everything else works. then i dont think its a switch. if replies after this one are slow to come, call local advance auto, oreilly's, autozone or anything. or pepboys. and just ask them a quick question. then if they say they cant tell you without paying. say you need to know what the issue is and if they have the part so you can come in. then dont come in if its an easy fix lol. gotta know how to word things.
Old Oct 19, 2009 | 5:33 PM
ristpin's Avatar
Thanks for the reply. I learned today that when the "cab air circulation" switch is on, the compressor cycles!! Turned that off and no more compressor cycling. Thanks again.
jjw
Oct 16, 2012 9:09 PM
jackrook
Jul 17, 2012 1:15 AM
ousooner74
Nov 26, 2011 11:19 PM
Flying Low
Corvette
Mar 28, 2010 9:03 PM
gunner5
Sep 22, 2009 5:08 PM
