1997 Suburban Head Gasket/Block Problems
Old Oct 20, 2009 | 9:50 AM
fuelman's Avatar
Default 1997 Suburban Head Gasket/Block Problems
Had a new engine installed August 2008, check engine light has continuously come on, mechanic could not find code and kept telling me to drive car it would take care of itself. I manufacture fuel additives one of them which actually helps clean out carbon and in many cases has helped customers who had check engine light problems so I listened to the mechanic as a new engine should not have had formation of carbon deposits so soon after installed,
Throughout the year I have kept getting the same response and now last week the vehicle overheated without any warning at all, when having the car towed to the mechanic he advised that the block was cracked and that this could only happen from the overheating, and the only solution would be to replace the engine another $3K.
Does any one know if there is a correlation between the check engine light and the overheating, mechanic keeps telling me check engine light only applies to exhaust issues.
Thanks in advance
Old Oct 20, 2009 | 2:19 PM
mudmaniac's Avatar
Ride of the Month
May 2009
You need a new mechanic, a 1997 has OBD II electronics that monitor just about anything, if you don't have a temperature gage to watch the check engine light could be related to over heating as well.
Old Oct 20, 2009 | 10:03 PM
MDTAHOE's Avatar
First off A new engine will not cause a check engine light. Second it can not "take care of its self". They only way to know if it had something to do with it would be to know exactly what the codes were. It is not likely that it did. What about a warranty on the engine? Why did it overheat? Was the part that failed causing it to overheat replaced with the engine?
Dads Toy
Oct 21, 2011 6:54 AM
mml47
Nov 10, 2008 6:26 PM
gulfcoastjoe
May 4, 2008 12:38 PM
Stirgen
Jan 5, 2008 11:03 PM
Stirgen
Jan 4, 2008 10:51 AM
