Go Back   Chevrolet Forum - Chevy Enthusiasts Forums > Brand Review > Engine & Internal
Old 10-24-2009, 09:41 PM
oniondip oniondip is offline
1981 Chevrolet C/K 10
Default Rebuilding the 350
haha well I should start with.. this is my first post.. in the Engine section :P hah. But right now I have a 1981 GMC, painted camo, lifted 6 inches sitting on 37's. Has a 1979 350 4-bolt main bored 0.030". Shes starting to run a bit rough so im rebuilding in the spring. It is a street/off-road truck, but mainly off road. I want all low end torque, and lots of it to get me out of some pretty serious mud holes. Anyways, I'm looking for a bit of guidance on my build, below are the links to the few main things that matter when rebuilding (cant list others cause i dont have my clearances for rings and bearings yet). So I'm looking at:
These pistons (doesnt say on info page but it is 11.88:1 comp ratio with a 64cc head)
http://www.jegs.com/i/Sealed+Power/844/H617CP/10002/-1
This head
http://www.jegs.com/i/Edelbrock/350/60909/10002/-1
This cam/lifter/push-rod combo (doesnt have specs, but im going for less lift and more duration since ill be idleing through alot of stuff, and a rough idle will make it a rough crawler)
http://www.jegs.com/i/Edelbrock/350/22015/10002/-1
and these rockers (not sure what ratio to use)
http://www.jegs.com/i/Proform/778/66907P/10002/-1
For head gasket ill be using a steel parted with a thickness of around 0.040".
If you havent noticed this is a very high compression build
Seem like a good combo? Anything i might be able to change to suit my needs?
Tags
22015 , edelbrock
HTML code is On
