Running Rough/Misfire
Old Oct 24, 2009 | 8:41 PM
timdogg1313's Avatar
Angry Running Rough/Misfire
I posted this in the regular forum with no response so hopefully I'll get some under this section.
CEL light is back on and spitting and sputtering again! Replaced distrib and rotor last time(August '09) and it took care of the problem(not injectors). Does anyone know if something could be killing the distributor cap and rotor? Replaced with AC Delco parts so shouldn't be bad yet. Plugs are AC Delco and replaced last time when this happened so wouldn't think it would be those either. How do you tell if a plug is fouled? FYI: seems to be worse when running steady.
It also sounds like I have an exhaust leak under the hood. Could this have something to do with it?
Thanks,
Old Nov 9, 2009 | 2:28 PM
wrong section
moving this post from the DIY\usefull threads to the tahoe\suburban general section
macmommy
Apr 22, 2020 1:23 PM
buddyleno
Mar 31, 2017 8:13 AM
kronzy
Apr 18, 2013 8:37 PM
Chevyboy28
Oct 4, 2010 4:40 PM
Biggumzmcgee
Nov 15, 2009 10:51 AM
