2016 Camaro
Platform: F-Body & Zeta.
89 camaro 305tbi to 350 carb swap
Old Oct 26, 2009 | 2:59 AM
chadwick's Avatar
Default 89 camaro 305tbi to 350 carb swap
has anyone done a 305tbi to 350 carb engine swap? just wondering what to do with the fuel pump. should i keep the current electric pump and install a fuel pressure regulator, or use a mechanical pump on the engine with no electric pump?
other than that and the HEI distributor to install, is there anything else to change?
Old Oct 27, 2009 | 4:55 PM
nauticstar87's Avatar
I would think a mechanical fuel pump would be best. I've been told that a few times. Because the pressure from the electric pump is to high, but if you put a regulator on there that maybe fine. I don't know what else. I'll be trying a 350TBI to carb swap in a year or so.
Old Oct 27, 2009 | 10:34 PM
chadwick's Avatar
yeah, maybe there is conversion kits somewhere. for mechanical pump i probably need to install a suction standpipe in the tank too. ??
HunterTheRed
Camaro
Jul 18, 2013 6:17 AM
sitsonhisbutt
Apr 25, 2013 10:01 PM
stanman
Apr 17, 2012 10:46 PM
shawnmid
Aug 4, 2010 1:19 AM
grem62483
Nov 29, 2007 12:02 PM
