Go Back   Chevrolet Forum - Chevy Enthusiasts Forums > Chevy Cars > Impala
Old 10-26-2009, 09:44 AM
samuelcb409 samuelcb409 is offline
Send a message via Yahoo to samuelcb409
Default 01 impala hard shifting problem
I have a 01 impala 2nd owner on it, originally all stock until i got it. Car has 166k and has been well maintenanced, New Plugs and Wires, Using K&N Air Filter, Royal Purple Full Synthetic Motor Oil, Radiator Flushed and filled back with Dex-Cool, Transmission serviced and all fluids changed regularly and are at proper levels.
Recently i started having a problem while driving around town from alot of stopping and going after the car warmed to normal temp. it starts shifting harder than usual, also car sometimes get a bit warmer than usual. While its cold or even on the highway its fine. No problems at all. Usually until i get into stop and go traffic it starts doing the same thing. Dont know whats wrong with it and would like some advice on what to fix or do to stop this if possble.
Thanks,
Sam
Old 10-26-2009, 04:11 PM
TheRabidWookie TheRabidWookie is offline
1995 GMC Sierra 1500
Sorry to be the bearer of bad news but my friend has an '01 buick century and he had the same problem. Im pretty sure its the same engine and tranny. He had replaced everything on the tranny inside and out, I mean sensors, filters, everything ! It would be fine for a while and then same thing. final result , replace tranny . I sincerely hope this is not your case. Good luck
Old 10-26-2009, 04:54 PM
jondoe28 jondoe28 is offline
I have an 03 ls w/ 140k, started shifting into gear hard once warmed up. I put a can
of seafoam trans tune for approx. 100 miles, then flushed out with 10 quarts. Shifts
fine again. Tranny fluid was dirty even with regular maintenance. Hopefully this works.
Old 10-27-2009, 04:15 PM
if i try this which fluid should i use, my dip stick says dex III only. any specfic fluid for better results? Also where did you get new filter dealer, autozone, etc.?
Old 10-30-2009, 09:32 AM
U used dexron. I never changed the filer, unhooked the line at the cooler and
flushed 2 quarts at a time up to 10. Would probably be easier to take it to a quick change
or dealer.
Old 10-30-2009, 08:02 PM
capucine capucine is offline
I had a 03 impala that started to experience hard shifting and hesitation from stop and after checking several sites on line I found that this problem has been occuring with the 65e transmission on tons of owners. The solenoids are the culprits. It is not a cheap job to repair. Mine had 160 k or 100,000 miles. I got rid of it and I bought a brand new 2009 uplander and I am very happy with it
Old 11-02-2009, 05:18 AM
milwaukee_01impala's Avatar
milwaukee_01impala milwaukee_01impala is offline
sounds like the PCS (pressure control solenoid) in the tranny. what ever you do, DO NOT get the tranny flushed at an oil change place or somewhere similar. this is very bad for the tranny. there is a filter inside the tranny thats supposed to filter out small particles in the fluid. the fluid always flows in the same direction. when you get the tranny flushed, like an oil change place will do, all they do is hook up the machine to the lines in the radiator and back flush the fluid. this means anything thats trapped on the filter will be pushed off the filter and back into the tranny somewhere.
Quote:
the best thing to do is drop the pan on the tranny, which will drain about 95% of the old fluid, replace the filter and refill with dexron6. dex6 is compatible with dexIII so nothing bad will happen if they mix a little bit. you can get the filter at just about any auto parts store.
__________________
2001 impala, 3.4, 1.0dhp pcm, fenderwell intake w/k&n filter, 2.5" downpipe-exhaust w/flowmaster 40, 17" helo slick rims, LED tail lights/front turn signals, multi color led LS cluster/ hvac controls, impala embroidered floormats, 20% tint, aftermarket moonroof, turn signal mirrors
Old 11-05-2009, 03:00 AM
if i did do this would it possibly get rid or the hard shifting or help out with it and also has anyone used this dex6 on there impala before? or would it be best to get the tranny fixed by a profesional shop... please help me out asap
Tags
01 , 100 , 2nd , buick , chevrolet , gear , hard , impala , mile , pcs , problems , shifting , shifts , solenoid , transtune
HTML code is On
