Heater Problems on a 98 Blazer
Old Oct 29, 2009 | 8:21 PM
Grizzly Bob's Avatar
Question Heater Problems on a 98 Blazer
Hi Everyone! I am new here on the forum .... But am glad to be here and hope to get some help .. and maybe help others.
I have a 98 Blazer, 4 dr 4wh dr 4.3 vortec motor with auto trans.
I have a heater problem.... it blows air out the ac vents ... turn the **** to heat floor or defrost and it will not switch over .... will not blow out heat when you turn the heat up ....
not sure what to even start looking for the problem... any and all help would be appricated ....
thanks
Bob
Old Oct 29, 2009 | 10:57 PM
devo098's Avatar
I have seen the control head cause this problem. What i would do is take the control head out and your main supply vacuum to the unit i think is a black line if i recall. you can attach a small piece of vacuum line to the black one and jump from the main vacuum line to the others and you should notice the positions change for each different color. Also the last one that i did was hissing a little when the control head was faulty. if they change position when you jump the lines you need a control head.
As for the the other problem with your heat not blowing out. Does it not Blow anything out the vent when you turn the fan up or does the air coming out not change temperatures?
Old Oct 30, 2009 | 7:02 AM
yes it is blowing out air.. but the temp does not change.... it stays cold
i will check out the control **** ... thanks for the reply ..
Old Oct 30, 2009 | 10:08 AM
therewolf's Avatar
Cool
The vacuum-type control units sometimes crack. Be sure all the vacuum lines are hooked up, and the control unit is free of cracks.
My thought is it's a control unit problem, since you can control neither the heat nor the vents.
Old Oct 30, 2009 | 8:45 PM
devo098's Avatar
agreed
Old Oct 31, 2009 | 12:32 PM
is the **** the control unit that may be cracked,,, or is it the unit that all the vaccum line connect to that may be cracked .... ???????
Old Nov 1, 2009 | 4:57 PM
devo098's Avatar
the unit that the vacuum lines plug into
Old Nov 1, 2009 | 5:22 PM
Default Thanks ....
Thanks for all the reply's and suggestions .. they have been very helpful...
Bob
as2higpark
Nov 25, 2020 10:59 AM
HHR Ratt
HHR
Oct 22, 2010 9:14 AM
boo5368
Dec 30, 2007 5:51 AM
Aerina
Feb 16, 2007 11:00 PM
marge simpson
Nov 25, 2006 12:30 AM
