Go Back   Chevrolet Forum - Chevy Enthusiasts Forums > Chevy Trucks, SUV's, & Crossovers > Silverado & Fullsize Pick-ups
Old 10-31-2009, 04:35 PM
gianelli280 gianelli280 is offline
Default Carb CFM question
Hello,
I'm currently building an engine and need a new carb for it. It is a 70's 350 with 2.02 heads and a comp cams mutha thumpr cam. Looking at high 9's : 1 compression. Has an edelbrock performer intake.
Any input is much appreciated
Old 10-31-2009, 04:36 PM
-oops, non EGR as well.
Old 10-31-2009, 09:49 PM
old dog's Avatar
old dog old dog is offline
Default carb
i would say 800 to 850 cfm eldebrock
__________________
william j allison
Old 11-01-2009, 04:57 AM
That much, eh? What if i were to go just over 10:1, i've been playing with that idea.
Old 11-01-2009, 07:26 AM
mudmaniac's Avatar
mudmaniac mudmaniac is offline
Ride of the Month
May 2009
1987 Chevrolet K Blazer
My Garage
I would think a 750 would be more than enough, I am not an engine builder by any measure but I don't think the compression ratio has an effect on the flow of the heads. That would depend on the intake, valve size and port size of the heads.
__________________
MudManiac
95 Tahoe 383cu.in./350hp/425ftlbs
6" lift 16x35x16 Boggers
Old 11-01-2009, 04:42 PM
desrtrat desrtrat is offline
a 750 cfm carb mite work to a point..BUT it will not get you into the high 9 sec. range if you are running GM 2.02 heads. good after market heads that complement your cam profile are needed. if your ready to run it, see it someone can lend you a 750 cfm carb, a do a couple of WOT runs with a vac. gauge on a manifold vac source. if your showing 5-7 in. of vac on the gauge, then go with a 850 cfm carb..
also check your intake profile for flow. need one good flowing over 6000 rpm
good luck
Old 11-01-2009, 06:40 PM
mudmaniac's Avatar
Ride of the Month
May 2009
My Garage
I may have misunderstood, but I don't think he said he was looking to run in the 9 second range. He was talking about compression ratio.
__________________
MudManiac
Old 11-02-2009, 11:36 AM
Definitely not expecting any runs in the 9's, but since you brought it up... No, the 2.02's were sort of a convenience, just wanted to know what would sufficiently fuel them, i figured 750 would be plenty. Thanks for the input!
Old 11-02-2009, 07:19 PM
Quote:
my goof..
750 will be good
HTML code is On
