I can't get the pilot bushing out of crank?
Old Nov 1, 2009 | 12:20 AM
Bill's Dad's Avatar
Default I can't get the pilot bushing out of crank?
she's in there.....I ttried prying and even trying to split w/chisel! It was a needle bearing arrangement. I need to put this into a fullsize automatic.
Old Nov 1, 2009 | 9:18 AM
Bill's Dad's Avatar
Originally Posted by 1Gary
sweet! Thanks for the tip...I'm on my way, Thanks!
Old Nov 1, 2009 | 12:12 PM
MDTAHOE's Avatar
I usually use a pilot bearing puller however believe it or not I have used wet toilet paper before.
Old Nov 1, 2009 | 1:10 PM
therewolf's Avatar
DNK how much room or how deep the bearing is, but a cheap tool I've used in the past with success is a mini screwdriver. The size that sometimes has a penclip attached to the handle.
What you do is grind the edge almost flat. Then heat up the point, and turn it about 60 degrees, maybe a little more, depending how it fits in the pilot hole. Try to wedge it between the housing and the bearing. Usually if the bearing pops out a few thousands of an inch it goes the rest of the way easier.
WD40, blaster,or diesel oil,(when they put it in little cans they call D.O. "liquid wrench") helps.
Old Nov 1, 2009 | 3:46 PM
Bill's Dad's Avatar
I got the puller from Advance, got it 80% and 1 of the ears on tool broke? I used a screwdriver to pop it out. time to drop her in...
Old Nov 1, 2009 | 7:39 PM
jeffs_62's Avatar
A little late for my input, but....... for future reference, I use a grease gun to fill the hole behind the bearing and a ratchet extension. just like hydraulics. Fill the hole with grease and pound the extension into the hole, topping off with grease as needed.
Old Nov 8, 2009 | 8:45 PM
Bill's Dad's Avatar
Yeah well with the sales slip,I would be getting my money back.
I had a free rental .....I heard about the grease. should have tried it....next time, Thanks for the replys!
Old Jan 31, 2010 | 1:30 AM
timmysouthpark's Avatar
"I use a grease gun to fill the hole behind the bearing and a ratchet extension. just like hydraulics. Fill the hole with grease and pound the extension into the hole, topping off with grease as needed." Works like a charm. <!-- / message --><!-- sig -->
89s10blazer
Apr 23, 2014 11:28 PM
Brian Perkins
Sep 4, 2013 11:44 PM
Flying Low
Corvette
Mar 29, 2009 7:56 PM
LarryD
Apr 9, 2007 1:14 PM
