Go Back   Chevrolet Forum - Chevy Enthusiasts Forums > Chevy Vans & Minivans > Astro
Old 11-04-2009, 01:18 PM
frankibseries frankibseries is offline
Default chevy astro wont start help
hello everyone I'm new to the chevy world so dont know much how chevy's work. my astro van stopped working one day and i found out that i wasn't getting any spark so i changed the coil,ignitor,coil pick up,cap and rotor thinking that it was going to solve my problem and nothing still not getting spark. i don't know what to try next, so has some ever ran in to this problem before? Register today for free or log-in if already registered to remove this ad!
Old 11-04-2009, 08:27 PM
Jeffro Jeffro is offline
Did you check the coil wire? Also, what year is this van?
Old 11-05-2009, 09:06 AM
ihatemybike ihatemybike is offline
Is spark going from the coil to the distributor?
__________________
Aaron
1999 Astro (Green - Daily Driver)
2WD, 4.3L, 3.23, 180k+ miles, FE2 steering
1997 Astro (Grumpy - $250 Rally Van)
AWD, 4.3L, 3.42, 308k+ miles original engine and transmission, $30 eBay fuel pump
1997 Astro (25% Off - Parts Van)
Bought to steal parts off for Grumpy, but I want to try getting the engine running.
My CarDomain
Prev Astros:2000, 1994, 1987, 1986
Old 11-05-2009, 10:29 AM
it's a 98. It has power going to the coil.when we replaced the parts we had the number 1 spark plug wire off and cranked to see if it was shooting spark and it did, so we hooked up the wire tried to start the van but it wouldn't fire up so we sprayed starting fluid in the intake and it fired up for two seconds and it died after that we couldn't fire it up no more spark so I'm puzzled. What should I try next?
Old 11-05-2009, 07:11 PM
bump!!!!!!!!!!!!!!
Old 11-05-2009, 08:04 PM
If it started with starting fluid, it has spark! Sure its not the fuel pump? You should hear it when you turn the key on. It is in the gas tank.
Old 11-05-2009, 08:30 PM
Quote:
Does that mean you checked for spark a second time?
Have you checked the fuel pressure? Most times the fuel pump doesn't completely die, just doesn't have enough strength to start/run the van. Thus you can still hear a pump run and not be able to start the engine.
__________________
Aaron
My CarDomain
Old 11-05-2009, 10:07 PM
We can here the fuel pump turn on and can smell the gas, as for the spark it stopped again. when we had spark we could here a clicking sound from the distributor when we tried to start and when we distributor stopped spinning. Now that we have no spark we don't here it anymore. So i took the distributor cap off to see if i had placed the rotor backwards but you can only put it on one way.I will check tomorrow if I'm getting power to the coil and the ignitor,is that clicking sound normal?
Tags
01 , 1999 , 99 , astro , cap , chevrolet , chevy , clicking , coming , die , distributer , fluid , forum , problems , sound , spark , start , starting , tahoe , van , wont
HTML code is On
