89 c1500 engine swap (not running)
Old Nov 5, 2009 | 12:33 AM
981500k's Avatar
Default 89 c1500 engine swap (not running)
Ok so to make this clear not my truck anymore but still my problem. My buddy took a running and very strong 350 out of a 90 suburban and put it in a 89 c1500 pickup, now it wont run. He didnt change over any of the intake or sensors. So whole engine for whole engine. a couple of plugs are different, mainly the oil pressure sensor. But will not fire. It sparks once but not again. What should we look for aside from being smart and just replacing the long block with another instead of intake manifold and all (his idea not mine). I would have just replaced the long block not the whole thing, could this be a problem?
Old Nov 5, 2009 | 6:30 PM
Speedy650's Avatar
did you put in new plugs when you swapped? and did you take the starter off for the swap?
Old Nov 5, 2009 | 7:57 PM
981500k's Avatar
No and no he realy dosnt know to much about it and since its in already Im not messin with that all I know is that it sparks once and very weak but not again until we key it off and back on again, and yes the battery is good and so forth we now that much
Old Nov 5, 2009 | 8:04 PM
Speedy650's Avatar
well, double check all connections. power, fuel, etc.
Old Nov 5, 2009 | 8:10 PM
981500k's Avatar
the biggest is that no the fuel pump does not turn on with key but that I think was linked to the one off plug we had that we are doing tonight but even with fuel dumped into it it wont fire. and to kinda add to it not that it matters but it literally ran the second before we pulled it out and it was transplanted that day along with the fact that the other engine indeed run to the very second before we pulled it out that same day. so just a little confused
Old Nov 5, 2009 | 8:25 PM
Speedy650's Avatar
that is strange. did you change computers as well? it could be a computer problem, not recognizing something. but if its the same engine, it really shouldn't matter...
Old Nov 5, 2009 | 8:39 PM
981500k's Avatar
good point no we didnt change computers. the truck originaly came with a 305 and what he is attempting is a 350 that i am not sure if is possible. the 305 was a 89 and the 350 was a 90 model year the only thing is that the 350 has cruise but not directly related to the issue
Old Nov 5, 2009 | 8:51 PM
Speedy650's Avatar
try pulling the computer from the burb and put it in the silvy and see what happens.
Old Nov 5, 2009 | 8:58 PM
981500k's Avatar
will try dont know if we'll get to it tonight thanks, Ill post what happens
Gdavenport
Feb 9, 2015 4:59 AM
darkabyss
Nov 10, 2014 12:08 PM
Dishtowel9733
Feb 22, 2014 8:11 PM
Dishtowel9733
Feb 22, 2014 8:10 PM
catfishtxk
Dec 27, 2010 11:50 PM
