Go Back   Chevrolet Forum - Chevy Enthusiasts Forums > Chevy Trucks, SUV's, & Crossovers > Tahoe & Suburban
Old 11-07-2009, 11:34 AM
tahoe5991 tahoe5991 is offline
Default injectors?
Alright i have a 1995 tahoe 2 dr sport 4wd and i drove it and all was good and then parked it let it sit about a week and went to start it again and nothing would not start i could not hear the fuel pump so i replaced it and still could not hear it so i checked all my fuses and relays and all were good so i just hard wired it to a toggle switch fuel pump now pumping and slii nothing i then checked to see if my injectors were working and nothing i tested the plugins and no pulsing what so ever so far i have changed the ecm and the ignition module and searched for broken wires and did not find any does anyone have any more ideas? oh and i have oil pressure when cranking and it will start up if i pour some gas in the throttle body but dies right out Register today for free or log-in if already registered to remove this ad!
Old 11-07-2009, 03:09 PM
can anyone help??
Old 11-07-2009, 07:50 PM
rubrhammer rubrhammer is offline
Did you replace the fuel filter? I'm not sure on that vintage if there is a fuel pressure port on the gas line. If you can find a black plastic cap on a fitting on the fuel line, take it off and depress the valve core (looks like a tire valve) and see if there is pressure. If not the filter is clogged. Even if there is pressure it may not be ENOUGH pressure. These motors are very sensative to the amount of pressure you have.
Bob
Old 11-07-2009, 10:30 PM
MDTAHOE's Avatar
MDTAHOE MDTAHOE is offline
If you have no injector pulse you may want to check the cam sensor. Do you have spark? Does your truck have a security light? Is it flashing?
__________________
SHOP FOREMAN/SERVICE MANAGER
GOSS GARAGE (PAT GOSS FROM MOTORWEEK TV )
AC DELCO TSS SHOP
ASE MASTER, L1 EMISSIONS CERTIFIED
HTML code is On
