Astro 1985-2005
Platform: M-Body
Tapping noise
Old Nov 9, 2009 | 10:11 AM
Aviator5's Avatar
Default Tapping noise
Hi all,
It is probably a general question about 4.3 engine.
I have 98' Astro with 200000 miles on it. It was developing a tapping noise that could be heard on transition from high revs to idle. A few days ago I started it in the morning and I heard this didtinct tapping noise, which sounded like a lifter to me. It desappeared as engine warmed up. I drove the van for couple of days and that noise never came back. Yesterday I was driving it as usual and after one stop that noise came back when I started it hot. It would disappear after a few minutes of driving. also I noticed that when it knocks the oil pressure is all over the map - low at low rpms, and tops up at higher rpms. When noise stops - the pressure is in the middle at all rpms. Any suggestions before I rip it apart to change the lifters?
Thanks in advance.
Also my coolant disappears, oil level is OK though, and no traces under the vehicle.
Old Nov 10, 2009 | 7:35 AM
Aviator5's Avatar
Oil is clean, will do rad test today, thanks.
Old Nov 11, 2009 | 9:57 AM
Aviator5's Avatar
No bubbles in the rad, and no white smoke. This morning was cold and that tapping noice was really pronounced, it muffled down quite a bit after motor warmed up. But comes back if I shut down for a while or idle it for a while.
Gman
Feb 29, 2024 12:49 PM
nisan17
Sep 25, 2007 12:08 PM
rjd37
Apr 8, 2007 10:24 AM
guessg
Dec 14, 2006 2:51 PM
guessg
Dec 8, 2006 5:58 AM
