S-10 & Blazer 1982-2005
S10 Wont Start - Fuel Issue
Old Nov 9, 2009 | 7:06 PM
holyearth's Avatar
Default S10 Wont Start - Fuel Issue
Specs:
2.2L 4 cylinder S10 1998 113K miles 5 speed manual
Current status:
Won't Crank
Symptoms that led to the current status (in order of occurence):
2 weeks ago - died after driving for 2 miles ... tried to crank it over and over again ... after getting towed home it cranked right over - like nothing ever happened
1 week ago - died again but I was able to re-crank it (I banged the fuel tank suspecting the pump was bad)
5 days ago - died and I was not able to re-crank it at all
Things I have done to try and fix it:
3 days ago - I replaced the fuel pump. I did this because while turning the key I did not hear it "priming." I was confident that my problem was the fuel pump. After replacing the pump the truck cranked right up. Worked fine for one day (approx 4 miles of driving). Then it died again and won't re-crank.
1 day ago - I replaced the fuel filter. I checked the schrader valve on the fuel rail right by the engine. I do not have a pressure gauge, but from what I can tell no fuel comes out and very little to no air escapes. Because of this test I assumed that the line is clogged so I replaced the fuel filter. Still doesn't crank.
Notes:
The car does crank (idles for a few secs then dies) when I use starter fluid in the air intake. Fuses/Relays seem to be fine. No "check engine" codes.
My thoughts:
I suspect that it's a fuel issue but I find it very hard to believe that the fuel line is obstructed/clogged.
What do you guys think?
Old Nov 9, 2009 | 8:53 PM
MDTAHOE's Avatar
When you say it does not crank, generally that means that the engine does not turn over at all. You either have a no crank/ no start or a cranking no start. Please clarify this for us. I am assuming you have a cranking no start but I want to be sure.
Old Nov 10, 2009 | 7:09 AM
holyearth's Avatar
The starter is fine. When I put the key in to start it it does try to crank but does not turn over.
slicedpi
Jun 13, 2023 9:45 AM
sleepingciv
Jul 25, 2020 1:03 PM
williezoom
Jul 1, 2013 7:11 PM
dj alacran
May 24, 2011 12:05 PM
