Engine: Running rough
Old Sep 24, 2006 | 4:30 AM
350Boy's Avatar
Default Engine: Running rough
I have a 1992 Blazer Full-Size and when I have the pedal hardly down at about 25 miles per hour it runs real rough. It sounds like its about to cut out. It's kinda like its running too rich, but its TBI. One thing I can think of is the temp. It won't register more than about 130, and it used to run 190-185 before the new engine. Everything is the same in design. I put in a new thermostat and new coolant temp sensor. Think maybe I could need a new O2 sensor? The exhaust smells strongly of gas, even after about 30 minutes of running. Thanks.
Old Sep 24, 2006 | 1:52 PM
uncle bill's Avatar
Default RE: Engine: Running rough
An O2 sensor should be part of the tune up on those Year models. Change it and Your plugs and do a good tune up.
Old Oct 18, 2006 | 11:24 AM
xkikbxr's Avatar
If ya haven't figured it out already...Check your EGR valve. It might have a pinhole leak in it.
Old Feb 14, 2007 | 6:46 PM
casyschmidt's Avatar
have you checked your timing it could be your cadillac converter is cloged
Old Apr 8, 2007 | 10:51 PM
350Boy's Avatar
Haven't seen my EGR valve in about 30k, wasn't thinking of that. My catalytic joke is fine.
sittinlow88
Nov 5, 2021 5:08 PM
macmommy
Apr 22, 2020 1:23 PM
ussva
Jan 8, 2008 8:50 PM
Jro
Oct 14, 2007 2:16 AM
btotheh33
Mar 11, 2007 3:30 AM
