Platform: J-body
97 Cavalier PCM / Alternator Noise
Old Nov 17, 2009 | 8:54 PM
NCIS,AZ's Avatar
Default 97 Cavalier PCM / Alternator Noise
1997 cavalier. The alternator is making a high pitch electrical sound (you have to put you ear up to it to hear it) after the engine is turned off. After pulling the relays, breakers, and fuses, it stoped when the PCM fuse was pulled. The 4.96 volts at the alt plug stoped also. I put the fuse back in and 0.0 volts and no sound. Restart the engine, the alt charges. Shut it off, and the sound is there, unplug the alt plug and have 4.96 volts. This is also draining the battary. What cha think?
Old Jan 22, 2013 | 3:50 PM
jakefisher48's Avatar
did you ever figure out what it took to fix it i am having the exact same issue i was told to replace the pcm?
Old Aug 9, 2013 | 8:24 PM
EddieW's Avatar
Has anyone figured this out? I'm having the same issue with a no start thats flooding the plugs and backfiring through the throttle body. The mechanical timing is correct the compression is correct the control module is good the crank sensor is good the map sensor is good I mean I have gone through this car and cannot figure it out. Any help at all would be greatly appreciated
Old Aug 10, 2013 | 7:19 PM
Bokoxthexchocobo's Avatar
I had this problem on my 97 Chevy Cavy RS, and it seemed to be tied into my Ignition Coil Packs, I ended up having a bad one, lol.
Old Aug 11, 2013 | 1:32 PM
EddieW's Avatar
Thanks for the reply, I have also changed the coil packs with known good ones I had laying around. I'm down to the computer screwing with the timing I have checked absolutely everything else.
Xerklite
Apr 27, 2013 9:14 AM
bass2112
Sep 21, 2012 10:43 AM
2000burb
Feb 28, 2012 12:42 PM
2000burb
Feb 4, 2012 6:56 PM
Drock77
Mar 10, 2007 10:09 AM
