Venture 1997-2005
Platform: U-Body
Starter engaging after start
Old Oct 12, 2006 | 12:24 PM
J57ltr's Avatar
Default Starter engaging after start
A friends Venture is engaging the starter after it's already started. It's the classic gringing as if you forgot you started the car. This one is a 01' model and I know that the computer controls actually engaging the starter and also prevents it from engaging once the engine is running. You can just bump the start position and the starter will stay engaged until the engine starts. Anyway that's the type of system it is. What would cause the starter to engage after the engine has already started.
Thanks
Jeff
Old Oct 20, 2006 | 2:16 AM
01_Venture's Avatar
Default RE: Starter engaging after start
If you happen to figure this out, I would appreciate it if you could let me know. I logged on to post this exact same problem with my 01 Venture. The dealership is planning on replacing the starter for me (since I just purchased it), so hopefully that will take care of the problem.
Old Nov 18, 2006 | 12:56 AM
01_Venture's Avatar
Replacing the starter took care of my problem.
Old Nov 18, 2006 | 1:06 AM
J57ltr's Avatar
It has not happened since I first posted so there is no way of knowing what caused it. My thoughts are either the starter is going bad, or it was reengaged after the start some how. Only time will tell.
Jeff
Jeff maggard
Jul 21, 2012 10:29 AM
bavant
Jan 16, 2012 2:12 PM
freedomfighter_87
Dec 7, 2009 7:32 PM
freedomfighter_87
Dec 3, 2009 6:30 PM
timdogg1313
Sep 9, 2006 7:01 PM
