daytime running lights
Old Oct 22, 2006 | 8:24 AM
stingray502's Avatar
Default daytime running lights
Hello
Same Problem like snoogs99tahoe: all lights work fine exept daytime running light. All fues okay. Any ideas? Herzlichen Dank für deine Antwort, Stingray502
Old Oct 22, 2006 | 12:36 PM
ZX1100F1's Avatar
Default RE: daytime running lights
First idea: Please don't start a new thread to address the exact same issue that a previous thread was posted for the same day.
2nd idea: Check DRL light bulbs, the bulbs used during assembly were provided by the lowest bidder and do not last very long, it is not uncommon for them both to be burned out.
Old Oct 22, 2006 | 1:53 PM
sjenkinzz's Avatar
And a devel to get to to replace...
Old Oct 22, 2006 | 2:03 PM
golfer's Avatar
ORIGINAL: ZX1100F1
Are the DRL lights separate??
I thought the DRL were the high beams at reduced current, at least this was the way it was done on my 00Express and 03 S10 if I recall correctly. Unfortunately they're not around to go and confirm.
Old Oct 22, 2006 | 2:13 PM
jlenkows's Avatar
This may sound silly, BUT....
check to make sure that your e-brake pedal is fully released. Not sure if they still do it this way, but in olden days, if the e-brake was ok, the DRLs wouldn't turn on.
Just my $.02
Old Oct 25, 2006 | 12:18 PM
They still did it the same way in 1999. Unfortunatly this is not the problem. Thank you!
Old Oct 25, 2006 | 12:31 PM
You're right, they aren't. Not high beams - the nother ones (sorry, I don't know the English word) at reduced current ( 70%), thank you!
RitualJman
15
Apr 22, 2026 9:15 PM
LTZ_HOE
Jul 5, 2025 7:00 PM
peacekeeper
Mar 17, 2010 2:00 PM
irishflies
Jan 9, 2007 10:56 AM
